Looking for carbon fiber trunk...?
Does any carbon fiber company make a trunk for 00' civic sedan? My local jdm shop said VIS does, so i went onto their webpage and only found it for 96-98. Are the 96 and 00 trunks inter-changeable? thanks -josh
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdm_Eg686 »</TD></TR><TR><TD CLASS="quote">Does any carbon fiber company make a trunk for 00' civic sedan? My local jdm shop said VIS does, so i went onto their webpage and only found it for 96-98. Are the 96 and 00 trunks inter-changeable? thanks -josh
'96-'00 are all the same when it comes to trunks. Just different colored tail lights.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TsujenDB1 »</TD></TR><TR><TD CLASS="quote">Call vis and ask them... I think that would be easier than asking people on honda-tech. aka common sense</TD></TR></TABLE>
Wouldn't it be easier to say "yes" instead of posting that?
</TD></TR></TABLE>'96-'00 are all the same when it comes to trunks. Just different colored tail lights.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -NA-aLL-thE-wAy- »</TD></TR><TR><TD CLASS="quote">'96-'00 are all the same when it comes to trunks. Just different colored tail lights.</TD></TR></TABLE>
not for sedans
Carbon Creations makes one for the sedan
not for sedans
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Machinehead115 »</TD></TR><TR><TD CLASS="quote">
not for sedans
Carbon Creations makes one for the sedan</TD></TR></TABLE>
Right, sedans use different taillights in the 96-98 and 99-00. I am 99% sure it bolts up, it just has the wrong shaped taillights. I could be wrong about that though.
not for sedans
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondizzle! »</TD></TR><TR><TD CLASS="quote">Right, sedans use different taillights in the 96-98 and 99-00. I am 99% sure it bolts up, it just has the wrong shaped taillights. I could be wrong about that though.</TD></TR></TABLE>
you're right, they are interchangeable between 96-98 and 99-00 but the inner taillights are different
not for sedans
True, but I thought it was obvious we were talking about sedans.
not for sedans
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -NA-aLL-thE-wAy- »</TD></TR><TR><TD CLASS="quote">True, but I thought it was obvious we were talking about sedans.
well your original statement's not totally true then, the inner taillights are different between 96-98 and 99-00
</TD></TR></TABLE>well your original statement's not totally true then, the inner taillights are different between 96-98 and 99-00
k peeps.
96-98
99-00
I know the trunk will fit as honda always just changes the tailights in the later years of the same car but the trunk will be swappable.
96-98
99-00
yea i could of called, just thought i ask the fellow members of H-T if they knew or who has one. I will check carbon creations or order one from VIS, thanks for everyone insight - josh
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdm_Eg686 »</TD></TR><TR><TD CLASS="quote">yea i could of called, just thought i ask the fellow members of H-T if they knew or who has one. I will check carbon creations or order one from VIS, thanks for everyone insight - josh </TD></TR></TABLE>
only bad thing is you'll have to downgrade to 96-98 tail lights.
ducsaim
Mar 19, 2011 07:17 PM
