Are these plugs oil soaked... or not? (pic)
Old Jul 31, 2008 | 10:02 AM
Honduh Chicken's Avatar
I fry gay turkeys
Default Are these plugs oil soaked... or not? (pic)
Turbo b18c1 has PLOOMS of oil coming from the exhaust. Doesn't really happen BAD until engine is at op temp. Not really specific of when it's happening either, but it IS however worse while it's building boost.
Pulled the charge pipe off, throttle body is CLEAN, no oil there. Pulled the plugs, can't tell if they look "bad" or not, they're dirty, but not as bad as I would expect if the oil was getting into the cylinders. Engine seems to run normal, compression is okay (for having 8.5:1 pistons). So is the oil JUST in the exhaust? or is it going through the motor?
Oil burnt, or not?
Old Jul 31, 2008 | 10:40 AM
1fastlude1's Avatar
Default Re: Are these plugs oil soaked... or not? (Honduh Chicken)
pull the charge pipe off the compressor and see if theres oil, if so turbo seals are shot if notdo a leak down test just cause u have good compression doesnt mean the oil rings are not shot, plugs dont look oil soaked
Old Jul 31, 2008 | 10:41 AM
thatblkguy's Avatar
have you done a leakdown?
it could be the rings thats the same issue im having on a coworkes turbo bandit
the plugs look normal
what plugs are they?
Old Jul 31, 2008 | 10:59 AM
I fry gay turkeys
Default Re: (thatblkguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thatblkguy &raquo;</TD></TR><TR><TD CLASS="quote">have you done a leakdown?
what plugs are they?</TD></TR></TABLE>
damn, I can't remember. They're NGK's and I remember we went a heat range down for turbo. I'd have to look at the number (they're back in the car now).
I think we'll do leakdown tonight. Cross your fingers.
Old Jul 31, 2008 | 05:56 PM
LSTEG96's Avatar
Default Re: (Honduh Chicken)
Im gonna vote too much crank case pressure, or a bad drain line.... and the oil is being pushed out the turbo straight into the DP
Old Aug 1, 2008 | 07:25 AM
JoePSI's Avatar
Default Re: (LSTEG96)
If the oils not coming from the engine theres only one other place, the turbo.
Old Aug 1, 2008 | 09:47 AM
EASY101's Avatar
* B A N N E D *
plugs dont look bad
VeryUnoriginal
Mar 20, 2014 08:15 PM
x_40oz
Dec 16, 2013 07:24 AM
Powelly
12
Sep 5, 2008 09:54 AM
powerdbygarrett
Jan 4, 2008 07:35 AM
dirtySOHC's
Apr 27, 2003 03:20 PM
