underhood heat
alright just a little question. after driving around for a bit i stop in at a tim hortins went and got a coffie and stuff. after that i had a smoke and drank my brew. after i thought id check my oil level poped my hood and MAN! felt so hot under there like i mean my themp gauge was reading perfect. i dunno how hot it is so pose to feel under there but i mean it was hot like pretty dam hot that u dident wonna touch nothing.. just curious is this normal to fell this hot
think about it this way depending on what your thermostat is. your engine is anywhere from 160 to 180 degrees.
by the way Tim Hortins has good coffee. Wife is from Mississauga.
Atleast you did not open the rad cap.
As stated above if you'd like it cooler upgrade your thermostat and rad cap and maybe flush your rad?It will always be hot but as long as your in the "safe zone'you should be ok
bump for timmies
bump for timmies
i have my downpipe rapped my turbo piping wrapped and have the hood raised in the back to try to lower the temperature but all doesnt seem to help much
just take the hood off
if he has a stock exhaust header does not really do much. I think actually it will help lead to cracking. I got told never wrap a stock header. Aftermarket fine but not sock cast iron headers.
