parts for a ZC motor.
hey i just got a car with a ZC motor in it n i cant seem to find parts for it anywhere.
im trying to find headers, intake, plugs/wires.. ect. what should i look up to find stuff for it?
dohc zc has 88-89 prelude 20 si timing belt, 86-89 integra head gasket, cyl sensor and distributor 88-89 teg,88-91 sohc water pump/oil pump also, manifold gasket intake and header are 86-89 teg along with valve cover gasket basicly everything in the head is 88-89 teg. block is all d16a6 88-91 si, timing belt is the weird one but its the only one. ive had more zc motors dohc then i can remember! sohc zc is 2 models also one is non v-tech the other is non one is 88-91 si d16a6, the other is 92-95 ex/si d16z6, d16z6 can use 96-00 ex with good results
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skywalker »</TD></TR><TR><TD CLASS="quote">dohc zc has 88-89 prelude 20 si timing belt, 86-89 integra head gasket, cyl sensor and distributor 88-89 teg,88-91 sohc water pump/oil pump also, manifold gasket intake and header are 86-89 teg along with valve cover gasket basicly everything in the head is 88-89 teg. block is all d16a6 88-91 si, timing belt is the weird one but its the only one. ive had more zc motors dohc then i can remember! sohc zc is 2 models also one is non v-tech the other is non one is 88-91 si d16a6, the other is 92-95 ex/si d16z6, d16z6 can use 96-00 ex with good results</TD></TR></TABLE>ya its DOHC non vtec. so ill need 2 order headers for a d16a6 88-91?
you dont need to buy 2 diffrent headers sohc one is just fine, just take the gasket trace the ports and grind them a little the holes are just a little up from one another, two headers cost to much and the grinding takes a few minutes, the clutch is from the 86-89 teg as well, if you have the zc trans that is, i have built many zc cars and loved them the most of all the honda motors. the best thing though for the clutch is bring it to the parts store and ask them for the alinement tool and just stick it in the splines
go to your local auto parts store for plugs and wires and look on ebayfor other crap unless you actually dont care to spend money and have niice things then look on JHP or passwordjdm or other junk like that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxAndy »</TD></TR><TR><TD CLASS="quote">what about a clutch kit that is 20t and 7 7/8 i cant find one?</TD></TR></TABLE>89 CRX/Civic Si D16A6
1991si
Mar 8, 2013 04:08 PM
Rainville
12
Dec 17, 2004 02:28 PM
