secondary butterflies
Old Jul 30, 2008 | 10:07 PM
islph22's Avatar
Default secondary butterflies
what do i need to do to remove my secondary butterflies and what wood i need on a b20a5
Old Jul 30, 2008 | 10:32 PM
Hawkze_2.3's Avatar
Default Re: secondary butterflies (islph22)
WAT?
Old Jul 31, 2008 | 06:55 AM
G2IntegraGS's Avatar
what wood you need on a b20....??? wtf?
Old Jul 31, 2008 | 06:57 AM
Acidcrakker's Avatar
Default Re: secondary butterflies (G2IntegraGS)
For a Civic.
And op, you would most likly need a dremel to cut out and smooth your butterflyies out.
You can buy one from BlackTrax, but thats just a waste of money when thats all they do.
Old Jul 31, 2008 | 08:29 AM
Hawkze_2.3's Avatar
Default Re: secondary butterflies (Acidcrakker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">For a Civic.
You can buy one from BlackTrax, but thats just a waste of money when thats all they do.</TD></TR></TABLE>
He strikes again with the missinformation....B20A5 is from a PRELUDE, not a Civic.
http://en.wikipedia.org/wiki/H...B20A5
I don't think they even have an IAB system, so what is the point of this thread?
Old Jul 31, 2008 | 08:51 AM
Default Re: secondary butterflies (Hawkze_2.3)
yeah and the spacer isnt just a iab plate with the butterflies removed. It is a completley new plate, no uneeded holes, and its plastic to help with heat transfer. I have heard that completly removing the plate and using shorter studs is the way to go. I'll be doing that on mine if I can find some shorter studs.
Old Jul 31, 2008 | 09:00 AM
vlang29's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">For a Civic.</TD></TR></TABLE>
L
O
L
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">And op, you would most likly need a dremel to cut out and smooth your butterflyies out.
or just remove the plate and use shorter bolts? And trust me, a blacktrax spacer isn't just a stock spacer with the butterflies removed.. its already gasket-matched, and works as a thermal barrier
Old Jul 31, 2008 | 09:17 AM
Default Re: secondary butterflies (vlang29)
Yeah I got your thermal Barrier.
******* a**holes.
Old Jul 31, 2008 | 04:37 PM
gstrudler's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2IntegraGS &raquo;</TD></TR><TR><TD CLASS="quote"> I have heard that completly removing the plate and using shorter studs is the way to go. I'll be doing that on mine if I can find some shorter studs.</TD></TR></TABLE>
Wouldn't that decrease your plenum volume a noticeable amount?
Old Jul 31, 2008 | 08:58 PM
vlang29's Avatar
Default Re: secondary butterflies (gstrudler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2IntegraGS &raquo;</TD></TR><TR><TD CLASS="quote">I have heard that completly removing the plate and using shorter studs is the way to go. I'll be doing that on mine if I can find some shorter studs.</TD></TR></TABLE>
it helps the top end a little bit, shortening the runners.
You don't need shorter studs, i just used about a 1" spacer on the existing studs. Not quite as pretty, but it works equally well.
Old Aug 1, 2008 | 07:55 AM
Cruiserdude's Avatar
Yes, it would decrease plenum volume, which is why you use a Blacktrax spacer. Don't just pull the piece out, guys, you're removing restriction in order to improve high-rpm breathing, yet you're decreasing plenum volume, which will hurt it.
Either:
1) Get a Blacktrax or similar spacer
2) Get a Euro-R (or Skunk2, though I don't recommend it) IM
3) Leave it alone and just get an S2k TB
turbotypeR@SPEC
May 1, 2008 05:26 AM
DJThomas1189
Suspension & Brakes
26
Mar 2, 2007 05:21 PM
Riddy
Sep 18, 2004 09:14 AM
littlenbk
Jan 6, 2004 04:25 PM
