what to do??? NO GRIP
i have a 94 teggy ls. i bought some new rims that will be here on the 28 or the 29, and we have races here on the 27. I'm ridin on stock stealies. I will put the air in the front down to about 22/23 and the back up to whatever. But these tires SUCK, any way to grip better or what??
Well this is a long shot, but I think they spray the track down with vht or something like that. If you could get a hold of some then spray it on your tires. I would go down to 22 psi and work from there. Also if you drop the clutch at the right rpm then you will neither bog, nor spin, but that takes practice. I launch about 2800 and drop the clutch, and usually get 2.2-2.3 60'. Thats the best i could do
