shaking and loud thumping noise?
Old Jul 30, 2008 | 06:23 PM
b16_704's Avatar
Default shaking and loud thumping noise?
ok so there's been a loud thumping sound and shaking coming from the front of my wifes 97 civic ex for months now and trying to figure out what it might be. it's the loudest a 2-3K rpm, and of course the faster you go the faster it sounds. i first thought it was the front rotors going out b/c that's kinda what it sounded like. replaced it w/ new front rotors/pads but didn't help. also thought it might be the wheel bearings but had the car jacked up and tried pushing/pulling on the front wheels but there's no play. so now i'm guessing it's the axles. i only thought the axles makes clicking noise when you turn? anyone ever had this annoying problem before?
Old Jul 30, 2008 | 07:08 PM
ekpunker's Avatar
Default Re: shaking and loud thumping noise? (b16_704)
Could also be a wheel bearing.
Old Jul 30, 2008 | 07:19 PM
iluvmy2000civicex's Avatar
Default Re: shaking and loud thumping noise? (ekpunker)
ek punker... Read the whole thread next time.
Old Jul 30, 2008 | 07:59 PM
geebs's Avatar
Default Re: shaking and loud thumping noise? (iluvmy2000civicex)
sometimes the inboard joint of the axle.. by the transmission.. if it starts to bind a little itll cause vibrations, shaking when accelerating.. i dunno about a thumping noise.. might be a hard/high spot in the tire?
Old Jul 30, 2008 | 08:01 PM
Make sure the tires and wheels are properly mounted and balanced. My buddy had a set on his GSR that were balanced and it sounded alot like what youre describing.
Old Jul 31, 2008 | 12:23 PM
b16_704's Avatar
i guess i'll check the ball joints this weekend and if it still looks good then i'm just gonna go ahead and change the axles...
Old Aug 5, 2008 | 05:46 PM
b16_704's Avatar
any other suggestions?
Old Aug 5, 2008 | 05:58 PM
sageuvagony's Avatar
Default Re: (b16_704)
When you guys ran over that cyclist over last week, did you remember to remove the carcass from underneath the car? Flesh and bones tend to hide in the smallest places under a car.
Old Aug 6, 2008 | 11:56 AM
b16_704's Avatar
Default Re: (sageuvagony)
no..i'm sure there isn't any body under there, plus i didn't even go to the bicycle race this past weekend..
Old Aug 6, 2008 | 12:13 PM
King V's Avatar
Wow. Since everyone's throwing parts at it, just put a front clip on it, powertrain and everything. I'm sure that'll fix it.
Ever bother to check the tires? Thumping noise....hmm...heard someone a few posts up mention a flat spot....or....Shifted cord/belt? Swap the tires front to rear before you spend more money on **** you don't need.
rc2904
Suspension & Brakes
Jan 27, 2015 05:49 PM
EK_MaGz88
Mar 17, 2011 02:32 AM
Josh.
14
May 30, 2005 09:47 PM
631 Teggy
Dec 29, 2003 07:55 PM
