Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Swift Racing Turbo Kit on 8th Gen FA5 Engine Build
Old Jul 30, 2008 | 05:36 PM
07CivicMD's Avatar
Default Swift Racing Turbo Kit on 8th Gen FA5 Engine Build
I wanted to create a new thread so I can post the latest PICs and information on my engine build and a glance of the Swift Turbo kit. The engine is complete and installed minus the wiring. All the pipe, exhaust and exhaust manifold fabrication is 98% complete. *Note that all the parts you see in on the car may or may not be available for the production kit. The exhaust is placed along with the downpipe and wastegate. Over the next few weeks the Haltech, gauges, boost controller, wideband and Fuel system will be installed. More PICs once those parts are installed.
This has been a pleasure to work with Mo at Swift Racing on this long process. I’ve learned so much over the course of tearing and building up the K20Z3. Cars has always been a passion and finally had the opportunity to create a unique car. I have always been a Mustang person since I was 14 and owned approximately 19 since that time. This is my first attempt in the ricer market and hope that this build can answer some of those nagging questions and over time someone can take this build one step further.
Engine Build Details:
Darton Sleeved Block (88mm bore resulting in a displacement of 2092.3cc vice the stock bore of 86mm and displacement of 1998.3cc) racing block.
Wesico Pistons (9:1 compression)
1260cc Injectors -
Carillo Rods
Modified Stock Oil Pump
ACL Racing Bearings
Cosmetic Gaskets and Seals
Modified stock Oil Pan
ARP Head Studs
Custom Tubular Exhaust Manifold
Snow Methanol Injection
Haltech E8v2
Custom Head Work - Stage 3 port (Decked and possible dropping compression to 8.75)
Carrillo Springs, retainers and valves (1mm oversized).
Swift Custom Intake *later this year. The intake will have custom fuel rail and billet runners.
Brian Crowler Stage 2 - turbo cams
Oil Stuff:
Swift Custom Oil Setup
Electronics Stuff:
Blitz Boost Controller
Blitz Turbo Timer
Innovate XD-16 wideband gauge
AiM MXL Strada wired to Haltech for instrument cluster for oil pressure, cooling temp, RPM and etc.
Fuel Return Stuff:
Swift Racing Custom Fuel Rails - with stock intake; the purchase of a Inline Pro Fuel Rail.
Braided Fuel lines with return setup
Swift Racing Technologies - Home
SRT Spec'd 6776E Series Precision Turbo.
TiAL 38mm Wastegate
TiAL BOV
Stainless Steel braided oil supply line with SRT exclusive oil supply tee. High Temp oil drain line
4" High flow lifetime cone filter
5Bar Map Sensor
Dual Walbro® 255lph High Pressure intank fuel pump
All Mandrel bent FULL POLISHED aluminum intercooler piping w/bead rolled ends
Custom Front Mount Intercooler rated at 650+HP
18-20PSI Maximum Boost Pump Gas - 22-24PSI on Methanol – Race tune later this year
Stainless Steel High Grade clamps
NGK Performance Iridium Spark Plugs, 1 step colder
3" Mandrel bent T304 SS race downpipe
3" Mandrel bent T304 SS front midpipe
Other Stuff:
Tein Coilovers Basics
Carbonetics - Double Carbon Clutch
Stock Engine mounts - Upgraded polyutherane
Custom braking
P2R throttle Body Gasket
Custom 3" Swift Exhaust system!
TL Type-S rims
Modified by 07CivicMD at 6:56 PM 7/30/2008
07CivicMD's Avatar
Default Re: Swift Racing Turbo Kit on 8th Gen FA5 Engine Build (07CivicMD)
Carrillo Rods
Weico Piston (9.0:1 compression)
Assembly of the Rods and Pistons. The adventure to a 10 sec 8th gen begins
Modified by 07CivicMD at 6:57 PM 7/30/2008
Old Jul 30, 2008 | 05:37 PM
07CivicMD's Avatar
Darton East K20 Sleeved Block
Stock Crank (Balanced)
Pistons are installed. Leak tested and holding 9.0:1 compression with no leaks. 88mm bore resulting in a displacement of 2092.3cc.
The Stock Oil pump was modified to increase the oil flow. Pockets where placed on the block underneath the oil pump to help with cavation.
Modified by 07CivicMD at 6:30 AM 7/31/2008
Old Jul 30, 2008 | 05:38 PM
07CivicMD's Avatar
Swift Racing Stage 3 Race port. The stock Honda heads are amazling huge. I wish I had closer PICs of the port but there are smooth and very sharp on the inside. Amazing port job!! And done by hand!
I planned to use Ferrera Valve train to complete the head. Spring, titanium retainer and 1mm oversize valves. Too bad it will only look like this before startup!
The head passed the leak down test with no leaks and after being decked the compression has dropped to 8.75:1 compression.
07CivicMD's Avatar
As you can see the motor is back in the car. I forgot to take PICs of the CAMS before they were installed so I hope these PICs will do them justice. BC Stage 2 Turbo CAMS.
Old Jul 30, 2008 | 05:39 PM
07CivicMD's Avatar
Final assembly of the Exhaust Manifold before the engine is place back in the car for good.
Engine Dampner
Finally back in the car for good!
Quick Glance of the turbo and intercooler piping
The heart of the build. Precision PT6776E T3 turbo!
Bottom View of the Turbo.
07CivicMD's Avatar
Swift Racing Custom Tubular Turbo Exhaust Manifold. I have several angles below
TiAL wastegate and placement with the Exhaust Manifold. Talk about a tight fit.
07CivicMD's Avatar
Quick Glance at the intercooler piping for the Swift Kit. Still waiting on the TiAL BOV so more PICs to come.
Kept my front bumper support and no modifying required! Good for 650WHP+
Old Jul 30, 2008 | 05:40 PM
07CivicMD's Avatar
Notice the Dump Tube that runs in tandom with the exhaust downpipe!
Custom Swift Racing 3" exhaust with Vibrant muffler and resonator.
07CivicMD's Avatar
Carbonetics Twin Disk Carbon
Innovate WideBand
Precision 1260cc injectors
Old Jul 30, 2008 | 05:41 PM
07CivicMD's Avatar
OK. Here's the link to the first Dyno run @ swift. I will post the Dyno sheets to most of my runs later this evening; along with some other random pics from the build. Enjoy.
Remember this is the first run. In the middle of converting the other runs and uploading to youtube.
YouTube - Swift Racing Turbo Kit 8th Gen (MDCivic07)
Old Jul 30, 2008 | 05:42 PM
07CivicMD's Avatar
Here's another run! This was the 2nd to last run.
YouTube - Swift Racing Turbo Kit 8th Gen (MDCivic07) 499WHP Run
Old Jul 30, 2008 | 05:45 PM
07CivicMD's Avatar
Here's the last run from yesterday even! Want to thank Mo @ swift and all the other mechanics that was part of the build. This run hit a peak of 21.5psi running to 8600 rpm. The head is built for more and plan to upgrade to the RSX oil pump is in the works for this winter. Remember the car is only 90% complete. Had to try to break the 500whp range so one last run!
YouTube - Swift Racing Turbo Kit 8th Gen (MDCivic07) 500 what?
Old Jul 30, 2008 | 06:41 PM
dirtySOHC's's Avatar
this is the most extensive build somone has done on this forum so far.
good luck....looks like you have everything figured out.
Old Jul 30, 2008 | 07:10 PM
ixion's Avatar
Wow, just ... WOW. This is awesome! I'm jealous... hehehe, this must have cost you a fortune?
Old Jul 30, 2008 | 08:59 PM
Farmer Brown's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 07CivicMD &raquo;</TD></TR><TR><TD CLASS="quote">
The Stock Oil pump was modified to increase the oil flow. Pockets where placed on the block underneath the oil pump to help with decavation.
I think you mean prevent cavitation. Decavitation isn't a word as far as I know.
Very cool! And expensive!
Old Jul 30, 2008 | 09:25 PM
K5^'s Avatar
K5^
Brand New
Excellent work. Props for all the detail you have posted.
Old Jul 30, 2008 | 09:28 PM
100miles+'s Avatar
From: In Diamond Bar, CA Brake Boosting like a Mother Focker!
Default Re: Swift Racing Turbo Kit on 8th Gen FA5 Engine Build (K5^)
+09797897 for the SI, IN FOR THE PICS
Old Jul 31, 2008 | 02:40 AM
FBP_Si's Avatar
Props for a well build. It looks liked it payed off in a good way.
Old Jul 31, 2008 | 05:32 AM
07CivicMD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ixion &raquo;</TD></TR><TR><TD CLASS="quote">Wow, just ... WOW. This is awesome! I'm jealous... hehehe, this must have cost you a fortune?</TD></TR></TABLE>
Thanks for the catch!
Old Jul 31, 2008 | 09:25 AM
Greg50Lt's Avatar
WOW. nice build. IF you ever go to the track to run it let me kno im in Md too.
Old Jul 31, 2008 | 09:56 AM
07CivicMD's Avatar
Default Re: Swift Racing Turbo Kit on 8th Gen FA5 Engine Build (Greg50Lt)
Should be heading to Capital the following Friday. Need time to break the rings in.
Old Jul 31, 2008 | 12:03 PM
BeauHance's Avatar
nice job i love that you did this to a sedan not a lot of people will expect what you have under the hood
Old Jul 31, 2008 | 03:42 PM
KlickityClack07's Avatar
Default Re: (BeauHance)
Very Nice!
Old Jul 31, 2008 | 08:04 PM
bin_dizzle's Avatar
Default Re: (KlickityClack07)
Not that I have the money but, how much for just the kit minus engine work?
