Engine Restorer?
I was in Napa the other day, getting some coolant and washer fluid and saw this stuff. Has anyone used it, and what were the results? The only thing I could find online were the companies claims. Is that basically what sea foam does?
I used it hoping to try and stop my leaky valve guides/seals but it didn't seem to help.
I do however seem to notice a slight power increase, but that might be in my head... I swear its got a little more pep though.
It does work to a certain degree, but it is not similar to SeaFoam, which is a cleaning / de-carbonising agent.
Just add a can with each oil change, but be sure not to overfill the crankcase.
Tell me this then..
I am getting one drop of oil from the driver-front corner (approx) of my engine about every 24 hours after adding this with an oil change.
I recently got the car and may have added a bit much, it is clearly over the second hole on the dipstick.
If I overfilled would I be getting a lot more than a drip?
caliskier
Oct 20, 2011 10:00 PM
jdm.boi408
Feb 8, 2011 07:24 AM
MdMaxPluR
Dec 2, 2010 01:45 AM
skate1968
21
May 1, 2007 07:52 AM
