FS: D-Series SOHC, D16 VTEC Head, Turbo kit, Garrett, Tial, Greddy, Vitara Pistons, tranny....
Old Jul 30, 2008 | 12:03 PM
turboLSef's Avatar
Default FS: D-Series SOHC, D16 VTEC Head, Turbo kit, Garrett, Tial, Greddy, Vitara Pistons, tranny....
<FONT COLOR="blue"><FONT SIZE="5">Stuff I need to clear out because build plans have changed! let me know if you have any questions
please bump!
</FONT></FONT>
<FONT SIZE="7">SOLD!</FONT>
Contact info: PM me here or email: nical@pcidiot.com
First off.. this is the Turbo kit I pieced together.. ALMOST complete! just need some fuel system and oil lines.. and a few others
<FONT SIZE="3"><FONT COLOR="green"> ** SOLD!! **</FONT></FONT>
Used Garrett AirResearch TB0321 - Specs I found online: Compressor Trim: 40; Compressor housing A/R: .42; Turbine housing A/R: .48; Horsepower Capabilities: ~250hp; Has an Internal Wastegate that a Website says is set at 7psi.. I'm not sure what it's actually at though... $SOLD to bizzaro_29
EBay Style Turbo Manifold - D-Series, T3 flange with a 38mm WG flange... has the braces running from exhaust flange to turbo flange $SOLD to bizzaro_29
Used "Spearco" Intercooler (I'll get the dimension later!) - I bought this with the small hole in it and tried to have the hole filled.. previous owner said he never noticed leak issues.. so should work $SOLD to bizzaro_29
Used Greddy Type- S Blow Off Valve, and Tial 38mm Wastegate - Both in great shape.. some light scratches Greddy BoV: SOLD to Got_EF8 ... Tial WG: $175 wastegate still up for grabs!!
Vitara Pistons (75mm) with Hasting Rings - Great setup for Boost!! these are the "YCP" coated cast pistons.. NEW power record on Vitara's: 471whp & 356 lbs/ft $SOLD to bizzaro_29
STR "Scalloped" Block Gaurd - Scalloped design allows maximum coolant flow $SOLD to bizzaro_29
Hondata Intake Manifold (Heatshield) Gasket - Reduces the transfer of heat from the head to the intake SOLD to Got_EF8
D16Z6 SOHC VTEC Head - mostly complete... comes with what you see! no dizzy or injectors.. looks to be in good shape, but bought used, so I dont know its true condition $SOLD to bizzaro_29
D16A6 SOHC Non-VTEC Long Block - Mostly Complete... no Dizzy, no Injectors. This Motor was in a friend's car ('91 CRX Si) and he had Nitrous on it.. it was pulled because it appeared to detonate in the intake manifold and now the brass looking plug oppisite end on the intake manifold from throttle body blew out and pulls in a lot of air.. $SOLD to bizzaro_29
Si Tranny (90-91 I believe?!) - I bought it used and was told it had no grinds or pop outs.. good amount of play with the input shaft and appears the main seal is done and needs replacing... $SOLD to bizzaro_29
<FONT SIZE="3">let me know if you have any questions</FONT>
Modified by turboLSef at 2:16 AM 9/6/2008
Old Jul 30, 2008 | 01:40 PM
turboLSef's Avatar
el bumpo
Old Jul 30, 2008 | 01:48 PM
EJ1ontheHorizon's Avatar
Default Re: (turboLSef)
TTT
Old Jul 30, 2008 | 09:06 PM
turboLSef's Avatar
Default Re: (EJ1ontheHorizon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1ontheHorizon &raquo;</TD></TR><TR><TD CLASS="quote">TTT</TD></TR></TABLE>
Old Jul 31, 2008 | 07:39 AM
turboLSef's Avatar
bumpskee
Old Aug 1, 2008 | 06:52 AM
wagalude's Avatar
Default Re: FS: D-Series SOHC, D16 VTEC Head, Turbo kit, Garrett, Tial, Greddy, Vitara Pistons, tranny....
how much for everything accept engine and head shipped to 29045
Old Aug 1, 2008 | 08:16 AM
turboLSef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wagalude &raquo;</TD></TR><TR><TD CLASS="quote">how much for everything accept engine and head shipped to 29045</TD></TR></TABLE>
pm'd
Old Aug 1, 2008 | 02:34 PM
turboLSef's Avatar
bump
Old Aug 3, 2008 | 02:56 PM
DADOHCturbo's Avatar
Old Aug 3, 2008 | 04:35 PM
Radim's Avatar
Default Re: (DADOHCturbo)
Old Aug 4, 2008 | 01:19 PM
turboLSef's Avatar
thanks for the bumps
Old Aug 5, 2008 | 01:49 PM
turboLSef's Avatar
up
Old Aug 5, 2008 | 05:43 PM
eg2jr's Avatar
bump
Old Aug 6, 2008 | 08:03 AM
turboLSef's Avatar
Default Re: (eg2jr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg2jr &raquo;</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
Old Aug 6, 2008 | 06:55 PM
turboLSef's Avatar
ttt
Old Aug 6, 2008 | 07:55 PM
weaksoN!'s Avatar
Old Aug 7, 2008 | 06:11 AM
turboLSef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weaksoN! &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Old Aug 7, 2008 | 09:11 PM
turboLSef's Avatar
bump
Old Aug 8, 2008 | 03:00 PM
turboLSef's Avatar
up
Old Aug 9, 2008 | 09:48 AM
turboLSef's Avatar
TTT
Old Aug 9, 2008 | 06:32 PM
turboLSef's Avatar
bump
Old Aug 10, 2008 | 10:07 AM
turboLSef's Avatar
I'M UP FOR OFFERS PEOPLE!!
Old Aug 11, 2008 | 05:40 AM
turboLSef's Avatar
bump
Old Aug 11, 2008 | 01:30 PM
turboLSef's Avatar
Old Aug 11, 2008 | 06:24 PM
turboLSef's Avatar
bumpo
