92 Accord Front Bushings
Hi,
All the front bushings (at least all the ones that are immediately visible when you take the front wheel off) are cracked.
What is the urgency of replacing these?
Thanks,
Scott
Thanks,
Scott
hows the steering on ur ride ?
does it pull to the side by any chance?
or does it jump to the sides when you hit a bump?
maybe you got uneven tire wear?
drive on the freeway?.......does it pull fast to the sides on the freeway?
if none of this happens to you daily then leave it alone!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by radiuslight »</TD></TR><TR><TD CLASS="quote">hows the steering on ur ride ?
nah, all is good.
I do hear a crunch when I go over a small bump slowly, but that probably the shock.
Ok, thanks. I guess the front end suspension with 317k miles still has a little more in it
nah, all is good.
