Need advises for b18b tuning
hi guys !
I've some questions to ask about modify a 95' b18b
1- How many lbs a clean b18b should have on each cylinder during a compression test ?
2- I planning to install CBR600 custom ITB setup .. some people says that I need camshafts to really see the difference .. is it right ?
3 - Witch camshafts are recommended for a b18b ? I heard good things about Brian Crower .. is it true ?
Thanks !
Thanks !
1. You are looking for cylinder consistency, not so much a high psi value.
2. You need compression & cams to really make it effective, furthermore a good flowing cylinder head.
3. This depends on the application (compression, intake manifold design, exhaust manifold etc..)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber »</TD></TR><TR><TD CLASS="quote">1. You are looking for cylinder consistency, not so much a high psi value.
because first of all I want to know if my b18 is in shape or not
and I only want to build a little N/A setup :
headers , exhaust , itb , cam , flywheel
nothing heavy .. just to give some little power to the b18 !
B_Something
Jan 26, 2005 08:03 AM
djay86
Aug 24, 2003 07:15 PM
