compression difference between b18a and b18b?
Old Jan 5, 2007 | 09:55 PM
ecksman's Avatar
Default compression difference between b18a and b18b?
after putting my lsvtec together i find out that my block maybe warped. the only thing i didn't do was get it decked.now i'm looking for replacement block. i used a b18b that was in the car would there be difference if i use the b18a block, like compression or crankcase? need to kmow asap cause their are a lot of good deals for b18a blocks and the b18b are little harder to find for a good price
Old Jan 5, 2007 | 09:56 PM
lVlemphizStylez's Avatar
Default Re: compression difference between b18a and b18b? (ecksman)
blocks are same go ahead with it
Old Jan 5, 2007 | 09:58 PM
ecksman's Avatar
Default Re: compression difference between b18a and b18b? (lVlemphizStylez)
same compression and everything? i always thought the b18a made less power and thought that was due to lower compression.
compression is the same
ecksman's Avatar
if this is true its going to be a big relief
Old Jan 5, 2007 | 10:01 PM
its true...same compression ....same rods...same pistons...same stroke...Same bottom end
Old Jan 5, 2007 | 10:02 PM
ecksman's Avatar
thanks for the help
Old Jan 5, 2007 | 10:03 PM
ecksman's Avatar
can sleep easy now
Old Jan 11, 2007 | 09:24 AM
flamega's Avatar
i'm sorry...then what the hell is the difference between the b18a and b18b then? LoL if you say everything is the same and all? no offence...just curious
Old Jan 11, 2007 | 09:39 AM
2ndgentegracer's Avatar
Default Re: compression difference between b18a and b18b? (flamega)
The only real difference between the two are I believe the intake manifolds are slightly different, and I know the cams are different.
Not too sure on the manifold though. Someone correct me if I'm wrong. The major difference would be the cams.
Old Jan 11, 2007 | 10:24 AM
IntegraLova's Avatar
Default Re: compression difference between b18a and b18b? (2ndgentegracer)
b18a is obd1. b18b is obd2.
Old Jan 11, 2007 | 11:56 AM
whoa its len 2's Avatar
Default Re: compression difference between b18a and b18b? (IntegraLova)
90/91 b18a... obd0, pr4 IM
92/93 b18a... obd1, pr4 IM
94/95 b18b... obd1, p75 IM
96/01 b18b... obd2a/b, p75 IM, different valve cover, PCV on valve cover
Only main difference with the blocks are the obd2 versions dont have the black box behind the block for pcv. All blocks are pretty much identical internally.
Old Jan 11, 2007 | 12:00 PM
doood's Avatar
been there done that
why not just have your block decked the least amount to get back straight?
CUL8RI1
Jun 12, 2004 05:40 PM
djay86
Aug 24, 2003 07:15 PM
V8'suck23
Apr 3, 2003 08:11 AM
The Destroyer
19
Jan 27, 2003 06:40 PM
donnie B
Jan 17, 2003 08:06 AM
