FS 93 EG H22 Euro R spec
1000 miles since rebuild h22A1.
93 Civic DX hatch 2.2 (210 whp 161ft-lbs of torque with stock header!!!!)
H22 A1 build;
Kaizenspeed balancer shafts eliminator kit, type S pistons, Crower stage 2 cams, BDL cam gears, Supertech springs & Ti retainers, port, polish & skimed head (0,02"), higher compression head gasket, Euro R manifold, heatshield gasket, F20B throttle body-65,5mm, Avid Racing motor mounts, Exedy stage 2 clutch, Streetlight flywheel, M2Y4 tranny, alu. bigger volume radiator, Gates racing radiator hoses, custom made axles, rebuild halfshaft, 2,25" stainless steel exhaust system (N1 style), polished valve cover, single crank pulley with harmonic balancer
Tuned on Crome Pro.
Suspension;
GSR brakes all around, new pads and rotors, rebuild calipers painted black, GSR booster, master cylinder and prop.valve, GSR lower control arms with hubs. New upper control arms, newer Monroe shocks (great for Chicago streets).
15'' GSR blades (will need new tires for winter)
Interior;
SI cluster, Kenwwod CD player with remote, alarm.
$5900!!!!!!!!!!!!!!!!!
Modified by ludecz at 7:18 PM 10/16/2008
Modified by ludecz at 8:22 AM 10/27/2008
H22 A1 build;
Tuned on Crome Pro.
Suspension;
Interior;
Did you read it? The block is from 94 Prelude Vtec it's been cleaned and honed in reputable machine shop. Type S pistons with OEM rings. The compression should be around 11,5:1 with the headwork.
I'd love to see how much it would make with a good header. I would give retune and dyno time for free to whoever buys it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludecz »</TD></TR><TR><TD CLASS="quote">Did you read it? The block is from 94 Prelude Vtec it's been cleaned and honed in reputable machine shop. Type S pistons with OEM rings. The compression should be around 11,5:1 with the headwork.
I'd love to see how much it would make with a good header. I would give retune and dyno time for free to whoever buys it.</TD></TR></TABLE>
yes i read it, im not knocking on ur build, its sick and id like to see what numbers itd push out but its still a mildly build h22 with a euro r mani
edit: part with the motor? shoot me a price
Sorry not parting anything out right now. All the parts in the build are brand new and I tried to stick with Honda parts as much as possible for long time reliability. This car was completely unmolested, not even 1 wire was cut.
Man that is [freak]ed up! I hate thieves. I'm in the burbs but I will keep a sharp eye out on craigslist for some of the more unique parts (That valve cover shouldnt be hard to miss if it goes up for sale). Sorry man, ride looks sick.
dude.. i was just gonna give you props on a nice stock looking ride.. oh man. i hope it gets back to you and some ******** just wanted a joy ride. someone might have stopped to get the key copied or something? wow wtf.
