Stock coil-overs
i have an 08 4D civic and i just bought new wheels that sit out farther than the stock wheels.When i go over a speedbump/shitty road the body comes down on the tire. Is there any way i can adjust the dampening on the stock coil-overs? or do i have to buy an after market pair?
what size tires and what offset rims do you have? maybe i can try to figure out what you can change to stop the rubbing. as far as "stock coilover" there is no such thing. the new civics have a mcpherson strut and coil spring suspension. there are no adjustments to be made on either strut or spring.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K5^ »</TD></TR><TR><TD CLASS="quote">225 is a tad on the beefy side with a 45 sidewall. You still could have fitted 215/45 on there on your wheels.</TD></TR></TABLE>
225x45x17 on stock height should be fine.
it sounds more like you went too aggressive (lower offset) than what your car is setup to be. offset?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kidnkorner »</TD></TR><TR><TD CLASS="quote">im running 225/45/17 on stock wheels needs a 1.5 drop bad</TD></TR></TABLE>
I rescind previous statement. I was thinking about something else.
Either trade your wheels to someone or look up a machine shop that can shave the mounting service of the wheels. If you want to explore the machining option I am located in Gilbert I can help you out, give me a call on Tuesday.
Shane
All Version Performance
480.626.5136
Shane
480.626.5136
