ALl possible LCA's - which is best bang for buck?
Old Jul 29, 2008 | 10:55 PM
stripes777's Avatar
Default ALl possible LCA's - which is best bang for buck?
92 civic hb
I'm redoing my suspension and noticed my rear driver side lca is bent a bit. i did some research and found out that most of the aftermarket lca's have a problem with their bushings.
is it best to just get some used 94-00 / 92-95 stock lca? how much and how hard is it to put new oem bushings into used oem lca? thanks!
Old Jul 29, 2008 | 11:12 PM
obuhmyuh's Avatar
Default Re: ALl possible LCA's - which is best bang for buck? (stripes777)
i went with blox, haven't had a prob yet, i have eg and itr lca's for sale if you want em.
Old Jul 29, 2008 | 11:22 PM
stripes777's Avatar
whats the difference between itr and eg lca? how much? do u know how much it is to press in new bushings?
Old Jul 29, 2008 | 11:28 PM
obuhmyuh's Avatar
Default Re: (stripes777)
[QUOTE=stripes777]whats the difference between itr and eg lca? how much? do u know how much it is to press in new bushings?[/QUOTE
ummm the eg's are just shaped a little different and are skinnier, eg and itr/gsr lca's and strut assemblies are not interchangeable. its gotta be ITR-ITR or EG-EG no mixing, the itr LCA is too wide for an eg strut ***. (ask me how i know haha). ITR also has a hole for a rear sway bar while stock eg's do not. i have no idea how much that would cost, nor do i know if its something you can do on your own.
Old Jul 29, 2008 | 11:31 PM
stripes777's Avatar
dam the bushings are a rip off, i just saw on the websites. makes it almost a no brainer to purchase aftermarket. damnit
how much you selling your eg ones? are they straight and not broken? my current one is bent and i dont need to buy a bent one, lol
Old Jul 29, 2008 | 11:32 PM
xd69's Avatar
Function7 or OEM
Dont bother with the rest
Old Jul 29, 2008 | 11:34 PM
obuhmyuh's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stripes777 &raquo;</TD></TR><TR><TD CLASS="quote">dam the bushings are a rip off, i just saw on the websites. makes it almost a no brainer to purchase aftermarket. damnit
how much you selling your eg ones? are they straight and not broken? my current one is bent and i dont need to buy a bent one, lol</TD></TR></TABLE>
nope, ill prob get em to you for like 35 shipped. i have some pics ill post em in a sec.
Old Jul 29, 2008 | 11:35 PM
stripes777's Avatar
Default Re: ALl possible LCA's - which is best bang for buck? (xd69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xd69 &raquo;</TD></TR><TR><TD CLASS="quote">Function7 or OEM
Dont bother with the rest</TD></TR></TABLE>
skunk2 is kind of wack too huh, i was reading about the polyurethane bushings
Old Jul 29, 2008 | 11:36 PM
obuhmyuh's Avatar
Old Jul 30, 2008 | 05:21 AM
EJ8freek's Avatar
Blox or Skunk2. They are both decent.
Old Jul 30, 2008 | 06:48 AM
iluvmy2000civicex's Avatar
Default Re: (EJ8freek)
Skunk 2 for ALL your suspension needs.
Old Jul 30, 2008 | 07:04 AM
Declectic's Avatar
I just picked up Function/Form LCA to go with the Function/Form coilovers I picked up, haven't installed them yet though but just mentioning it.
check out weaksauce.org in the hondatechmarketplace under the suspension section, they have a whole slough of LCAs to choose from
Old Jul 30, 2008 | 08:22 AM
d357r0y's Avatar
Unless of course you know about mfactory parts..
http://www.teammfactory.com/
Old Jul 30, 2008 | 08:33 AM
pdiggitydogg's Avatar
I'll agree with this. F7 lca's have a lifetime warranty, have their own custom poly bushings, rather than "ots" bushings, and offer a range of swaybar mounting points for adjusting tension.
F7's and MFactory are the only thing Id buy...the rest are just toys.
Do you need them anyway? No, probably not.
I went with F7s because 3 of my stock lca bushings were shot and the price for new oem or new bushings + having them pressed was close enough to justify the ease of just getting new F7s.
Old Jul 30, 2008 | 09:36 AM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by obuhmyuh &raquo;</TD></TR><TR><TD CLASS="quote">ummm the eg's are just shaped a little different and are skinnier, eg and itr/gsr lca's and strut assemblies are not interchangeable. its gotta be ITR-ITR or EG-EG no mixing, the itr LCA is too wide for an eg strut ***. (ask me how i know haha). ITR also has a hole for a rear sway bar while stock eg's do not. i have no idea how much that would cost, nor do i know if its something you can do on your own.</TD></TR></TABLE>
ummm what?
the ITR and EG rear and front LCAs are swapable. Only the EKs are not swapable.
I (and many on here) run ITR LCAs on EGs, zero fitment issues.
Keep in mind that the ITR rear LCA uses a different design with a shock that has the bushing in it and the EG/teg style (your pic) has the bushing in the LCA. So different shocks are in order if you swap them, but there is no difference as far as mounting to the car or trailing arm.
replacing the bushings requires a press and a couple 1/2 drive sockets to use as spacers. Takes about an hour to replace them once the LCA is out of the car.
Old Jul 30, 2008 | 11:15 AM
obuhmyuh's Avatar
Default Re: (Relic1)
[QUOTE=Relic1]
Keep in mind that the ITR rear LCA uses a different design with a shock that has the bushing in it and the EG/teg style (your pic) has the bushing in the LCA. QUOTE]
the itr LCA is too wide to allow the stock eg strut to fit over it, so you can get a bolt through it is what i was saying, so if you need to get a "different design" with ur strut then they're not interchangeable. i tried putting ITR lca's on my car with my tokica illuminas and everything fit perfectly, except i couldn't get the strut to mount to the LCA.
im trying to tell him if he's not changing anything except for the LCA's then the ITR ones wont fit with a stock setup.
if I'm wrong please clarify, i dont want to post bs, and im just speaking out of my own personal experience. thanks
Old Jul 30, 2008 | 11:17 AM
obuhmyuh's Avatar
Default Re: (obuhmyuh)
these are the ITR lca's i have, you can see the difference in width, where the strut mounts to the LCA
Old Jul 30, 2008 | 12:18 PM
Right, they wont fit, because the itr lca is designed to have the shock fit inside, not over, it.
Both you two are making the same point, but saying it differently
Old Jul 30, 2008 | 12:25 PM
obuhmyuh's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">Right, they wont fit, because the itr lca is designed to have the shock fit inside, not over, it.
Both you two are making the same point, but saying it differently </TD></TR></TABLE>
haha that's what i was trying to say, but thank you for clarifying
Old Jul 30, 2008 | 01:21 PM
s2kholic's Avatar
best bang for your buck, they are pretty expensive....but like everyone else said the function 7's have the lifetime warrenty. I love mine, def worth the money =0P
Old Jul 30, 2008 | 08:05 PM
stripes777's Avatar
i think im going to pick up some new oem integra ones, that way i can put on some rear sway bar in the future. aftermarket is a bit expensive and i dont want to deal with wack bushings. thanks all
the regular teg lcas do fit the 92 civic tho right? isnt that how eveyrone puts rear sway bar on?
Old Jul 30, 2008 | 08:18 PM
MonkeyBoy668's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stripes777 &raquo;</TD></TR><TR><TD CLASS="quote">the regular teg lcas do fit the 92 civic tho right? isnt that how eveyrone puts rear sway bar on?</TD></TR></TABLE>
Yes, EG & DC (except ITR, as already covered) rear LCAs are interchangeable, but depending on the trim level you may or may not get a connection for a rear sway. GSRs came with rear sway, but I'm not sure about the lower trims.
Nevertheless in all cases the suspension geometry is the same, there are just minor differences (different spring rates, mounts for sways, ABS, etc) between parts.
Old Jul 30, 2008 | 09:23 PM
stripes777's Avatar
i found the part numbers for a 94 teg lca. now to see how much my friend at honda gets them for, thanks guys!
Old Jul 31, 2008 | 05:52 PM
DavidR's Avatar
Default Re: ALl possible LCA's - which is best bang for buck? (d357r0y)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d357r0y &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.teammfactory.com/</TD></TR></TABLE>
With an incorrect placement of the swaybar endlink, I'd be hard pressed to recommend those.
Old Jul 31, 2008 | 05:59 PM
d357r0y's Avatar
Default Re: ALl possible LCA's - which is best bang for buck? (DavidR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DavidR &raquo;</TD></TR><TR><TD CLASS="quote">
With an incorrect placement of the swaybar endlink, I'd be hard pressed to recommend those. </TD></TR></TABLE>
This is the 1st I've heard of it, any more information?
