99gsr with a ITR Cluster Rpm issue
Old Jul 29, 2008 | 08:43 PM
Ricky616's Avatar
Default 99gsr with a ITR Cluster Rpm issue
I have a 99 gsr with a itr cluster im guessing its a 99-01 cause it has immobilizer light on it. My car wont rev past 5k on the speedometer when in neutral or running but the car does rev past 5 it just wont go over 5k on the cluster, what can be the issue?
Modified by Ricky616 at 6:34 PM 8/9/2008
Old Jul 30, 2008 | 12:03 AM
wegotmorrison's Avatar
Default Re: 99gsr with a ITR Cluster Rpm issue (Ricky616)
First off, its pointless to have an ITR Cluser in a stock GSR.....
Old Aug 4, 2008 | 01:23 PM
Evolution-93-Ex's Avatar
From: Your mommas bed, that might be true too ..., So Cali, USA
Default Re: 99gsr with a ITR Cluster Rpm issue (wegotmorrison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wegotmorrison &raquo;</TD></TR><TR><TD CLASS="quote">First off, its pointless to have an ITR Cluser in a stock GSR..... </TD></TR></TABLE>
haha thats cold blooded
Old Aug 5, 2008 | 06:42 PM
end005's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricky616 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 99 gsr with a itr cluster im guessing its a 99-01 cause it has immobilizer light on it. My car wont rev past 5k on the speedometer when in neutral or running what can be the issue? </TD></TR></TABLE>
maybe I'm missing something, but you can't rev past 5k rpms? or is it that your RPM needle won't go past 5k rpms?
Maybe its the same concept, but I have a 98 gsr. I swapped out the gauge cluster for a 00-01 stock gsr cluster (I had the cool-lookin white gauges from the previous owner). The cluster was acting all funny cause I just did a "plug and play." I ended up swapping the gauges clusters from the 00-01 cluster and placed them into my 98 gsr cluster housing. Plugged them in and it worked like normal.
I think its that green film behind the ITR cluster that is different from the green film behind your GSR cluster.
...and if I'm wrong, I'm sure someone else can give you better insight.
Old Aug 5, 2008 | 08:14 PM
M3Stylz's Avatar
I just swapped a ITR engine into mine. Im having somewhat the same problem. When i hit 5k the needle will drop but i am still able to accelerate. A friend of mine said it was my conversion harness and he is going to be fixing it on Thursday. Could it be the cluster?
Old Aug 5, 2008 | 11:43 PM
pkdog167's Avatar
Default Re: (M3Stylz)
There is a write up on the FAQ, the 94-98 and 99-01 have different pinout for the cluster.
Old Aug 6, 2008 | 05:20 AM
M3Stylz's Avatar
So if my engine is a 96 spec and my car is a 01 that would make a difference? Thats why i got the OBD 2b-2a conversion harness
Old Aug 9, 2008 | 05:31 PM
Ricky616's Avatar
ok my engine is a 99gsr and my car is a 95 converted to obd1 with a obd1 ecu so the problem is the pinout?
Old Aug 9, 2008 | 06:16 PM
xprohx's Avatar
I think too much
Default Re: (pkdog167)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pkdog167 &raquo;</TD></TR><TR><TD CLASS="quote">There is a write up on the FAQ, the 94-98 and 99-01 have different pinout for the cluster. </TD></TR></TABLE>
[FAQ] How To Install An Integra Type-R Cluster Into Your Non-ITR Integra (GSR, LS, etc...)
ijust1agame
Jan 12, 2008 07:43 PM
blkackteg
Mar 4, 2007 09:19 AM
h23vtec_dc2
Apr 7, 2006 10:13 AM
jdm_lvr
Nov 26, 2005 12:28 PM
93civiceg6
Feb 22, 2005 06:57 PM
