Ex rear sway bar on an lx
Old Jul 29, 2008 | 07:01 PM
EF'nA's Avatar
Default Ex rear sway bar on an lx
I have a 94 lx 4 door just wondering if an ex rear sway bar will bolt up?
Old Jul 29, 2008 | 07:24 PM
AccordVT's Avatar
Default Re: Ex rear sway bar on an lx (EF'nA)
I wouldn't imagine Honda would put totally different suspension components on different sub-models. I think the EX just has the rear sway installed. As long as the distance from trailing arm to trailing arm is correct it should work. From looking at a diagram it looks like the rear stabilizer bar has endlinks (a peice of metal with a bushing on either end) One end attatches to the bar the other to the rear trailing arm. The end link is bolted through/to the trailing arm. So you may have to make holes in the trailing arm to mount the endlink, you may not but either way you will need the bar, endlinks and bushings, as well as the bar mounting bushings, also check for bolt holes in the body for the mount bushings.
DJ4Jesus77
Honda Civic (2001 - 2005)
18
Apr 16, 2013 11:41 PM
Serdar
Suspension & Brakes
11
Mar 26, 2010 02:49 PM
pjr710
10
Apr 16, 2006 04:41 PM
94hondaaccordlx
Nov 4, 2004 08:12 PM
jdowen2
Mar 10, 2003 03:20 PM
