FS: Semi Built B16 Block, GSR Head, Turbo Mani,DP,DT
NEW PRICES AS OF 8/30
UPDATED
Time to clean out the garage and get some money to finish my project. All of the prices are OBO. I would prefer to sell local, but will ship at buyers expense. Everything will be sold based on who pays first.
Selling becuse i am going stockish.
Semi Built B16 Block $1277
Block has about 570 miles
Block:
-Since first run i have been using Valvoline 5w30, honda coolant, and honda oil filters and has had several oil changes
-I wiped the cylinders down with oil and have kept the block covered since the head was removed(thats why you can see oil in the cylinders)
-Just run for break in with NO boost
-Built by Performance Engine and Machine in Middelton, WI
-Cleaned, Resurfaced, Rotating assembly balanced, Bearings coated, Pistons thermal coated
-9:1 Mahle Pistons
-Eagle Rods
-Race Engineering Block Guard
-New Oil Pump
-New Water Pump
-New Tensioner
-Toda Timing Belt
-New Bearings and Thrust Washers
-ARP Head Studs
-All timing covers
-All new gaskets and seals
-Will come with stock crank pulley, not the Fluidamper
-New Thermostate
-Doesnt come with a knock sensor
Modified by civiwhip at 11:32 PM 9/26/2008
Modified by civiwhip at 1:33 PM 10/5/2008
UPDATED
Block:
-9:1 Mahle Pistons
-Eagle Rods
-New Oil Pump
-New Water Pump
-New Tensioner
-Toda Timing Belt
-ARP Head Studs
-All timing covers
-New Thermostate
