Typical RPM's while going 65 mph?
Old Jul 29, 2008 | 05:33 PM
ketchup's Avatar
Default Typical RPM's while going 65 mph?
I've noticed my car is at 3k rpms while cruising at 65mph, in 5th gear - to me this is a little high? The motor [94 H22A] and ecu is stock - 8lb fidanza flywheel with stage 1 exedy clutch [m2b4 w/LSD].
I don't know what would be responsible for the RPM's at certain MPH, besides gearing?
Old Jul 29, 2008 | 06:13 PM
Kronn 98SH's Avatar
Default Re: Typical RPM's while going 65 mph? (ketchup)
Your transmission plays the biggest role. I'm at 3250rpm at 65mph. Normal for 5speed 5th gens.
5th gear RPM/MPH ratio:
2000/40
2500/50
3000/60
3500/70
4000/80
4500/90
5000/100
5500/110
6000/120
6500/130
7000/140
redpreludesi's Avatar
i have the h23a1 and when i run 60 im at 3k too im not sure if its the gearing in them or not but good thing you brought this up i wanna kno too
Old Jul 29, 2008 | 06:37 PM
ketchup's Avatar
Default Re: Typical RPM's while going 65 mph? (Kronn 98SH)
just the info I was looking for Where did you get it from?
yea, I found it awkward to be at/above 3k rpms going 65mph. I believe tire diameter is also a factor.
Old Jul 29, 2008 | 07:49 PM
5SpdH22's Avatar
something gnarly
Active Streak: 30 Days
Tire diameter hardly changes it, but it will a little bit. There's a conversion calculator on discounttire.com.
My rpm:speed ratios are pretty much the same as the list above. (with an m2a4)
edit: here's that calculator... http://www.discounttire.com/dtcs/infoTireMath.dos
Old Jul 30, 2008 | 02:53 AM
Edul59's Avatar
Default Re: Typical RPM's while going 65 mph? (5SpdH22)
h23's engines seem to run at a higher rpm at 65mph than that of the h22
Old Jul 30, 2008 | 04:23 AM
Kronn 98SH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ketchup &raquo;</TD></TR><TR><TD CLASS="quote">just the info I was looking for Where did you get it from?</TD></TR></TABLE>
personal experience....FYI, cops don't appreciate you testing your top end, so watch out.
Modified by Kronn 98SH at 8:50 PM 7/30/2008
Old Jul 30, 2008 | 08:25 AM
ya but when he is at 65 he is at a higher rpm than me so it seems to be about the same if im at 60 and doing 3k so if he would be doing 60 he would be doing 3k too right...
Old Jul 30, 2008 | 04:50 PM
ketchup's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kronn 98SH &raquo;</TD></TR><TR><TD CLASS="quote">[QUOTE=ketchup]just the info I was looking for Where did you get it from?QUOTE]
personal experience....FYI, cops don't appreciate you testing your top end, so watch out.</TD></TR></TABLE>
haha good thing you did it for me
Old Jul 30, 2008 | 09:48 PM
HdeucedeuceA's Avatar
62 puts me right at 3k with my M2B4.
Old Jul 31, 2008 | 08:55 AM
G2IntegraGS's Avatar
Sounds right to me. Ohh and the transmisson and overall tire diameter are the only things that affect speed at a given rpm. Unless you clutch is slipping.
Old Jul 31, 2008 | 09:03 AM
vlang29's Avatar
Default Re: Typical RPM's while going 65 mph? (G2IntegraGS)
tire diameter won't affect your speedometer though. if you're at 3K@60 (indicated)mph; with larger diameter tires you'll still be 3k@60 (indicated)mph but the actual speed will be higher than 60.
Old Aug 6, 2008 | 12:37 PM
Lovemy99Lude's Avatar
With my '99 base Prelude...I'm running 3500 rpm's at 78 mph.
catfishracer4748
Feb 27, 2010 10:20 AM
killerB16A
Aug 3, 2006 10:57 PM
98prelude98
Sep 4, 2004 09:29 PM
uNF$@#!
May 25, 2002 12:12 PM
MRXMUFFIN
Apr 17, 2002 10:48 PM
