Throttle body coolant lines...
First off... what does this valve do on the bottom of the throttle body?
Then, would it be a good idea to bypass it and go straight to the IACV?
Its a fast idle thermo valve I know on the newer throttle bodies it just has the inlet and outlet it doesn't have the entire setup like the older ones.
You'll have a shitty idle till the car warms up if you remove it. leave it on there or else youll have major problems keeping the car running when its cold.
basically it's a valve that contains thermowax that expands and contracts with the change of temperature which opens and closes a pintle that allows air to bypass the throttle body.
the idle air control valve controls idle aside from the FITV, mostly for running at operating temperatures.
dem0nk1d
14
Mar 22, 2006 05:57 PM
smash fascism
Apr 10, 2005 06:39 AM
