Was changing my coolant and uh oh!!!!!
Old Jul 21, 2002 | 06:21 PM
jdmspoonitr's Avatar
Default Was changing my coolant and uh oh!!!!!
It appears that I have mildew or mold or some kind of fungus growing in my coolant reservoir. the mold got up through the rubber hosing too. Then i checked the radiator and the mold was there too. AGHhhHh!!!! is there anyway to remove this crap from my radiator???? Anyone else have this problem???This is the first time this has happened to me. What could have caused this?
Old Jul 21, 2002 | 06:32 PM
Default Re: Was changing my coolant and uh oh!!!!! (jdmspoonitr)
Just my luck...I assume that this only happened to me. I just hope that whatever this crap is, that it won't hurt performance down the line.
Old Jul 21, 2002 | 06:34 PM
ZygSpeed's Avatar
What's the difference between mold and greenish sludge?
And do you teally think the mold would have survived in your radiator
(if the car's been running lately).
Just clean out the bottle and ... btw, when was the last time you changed the coolant?
Old Jul 21, 2002 | 06:41 PM
Default Re: Was changing my coolant and uh oh!!!!! (Zygspeed)
thanks for the reply. I must have neglected changing it for like at least the past 3000 miles. I'm not sure if it is sludge or mold????It could be either. Actually when i look at it, there is like grit to it. it's not smooth like sludge or mold, it actually looks like green sand. can't explain it. I drive the car fairly often. The rubber hoses were filled with this junk. I would assume that running the car often would make it so this kind of thing would not happen, but nonetheless, how could this stuff survive in my cooling system when the coolant is so hot????Hmmmmmm....one can only begin to wonder what this mysterious sludge is......
Todd00's Avatar
I said I don't want a title!
lol, a new strain of mold that can withstand boiling temps
Just drain, flush a few times and put fresh stuff in there (using a *distilled* water and coolant mix) and recheck everything in a few months. If you see the same problem then, you might have other issues.
[Modified by Todd00, 10:42 PM 7/21/2002]
Old Jul 21, 2002 | 06:43 PM
Default Re: Was changing my coolant and uh oh!!!!! (Todd00)
could using normal tap water have caused this? I also used water wetter in the past, could it have caused this??? I have not used water wetter ever since my friend told me that it might leave deposits. does anyone know if water wetter is safe for the car? thanks for all the help guys
Old Jul 21, 2002 | 06:46 PM
Todd00's Avatar
water wetter is fine--tap water is a big no-no. use distilled water and distilled water only.
Old Jul 21, 2002 | 06:48 PM
thanks for the help. I assume using tap water is bad because it has mineral deposits and other junk in there. Any other reason why not to use tap water?
Old Jul 21, 2002 | 06:51 PM
Todd00's Avatar
Isn't that reason enough?
Old Jul 21, 2002 | 06:55 PM
Dave-ROR's Avatar
Todd: What about JDM Tap Water?
Old Jul 21, 2002 | 07:04 PM
BABY NSX's Avatar
It's one of those life forms that hang out near undersea vents. Be careful I hear some can be quite toxic!
Old Jul 21, 2002 | 07:57 PM
Tommy_Gunns's Avatar
How about Brita water or filtered water???
Old Jul 21, 2002 | 11:57 PM
type r 01-1063's Avatar
so where can you get distilled water? at the auto parts store or do you have to buy them in bottles at the grocery store?
Old Jul 22, 2002 | 12:16 AM
GZR4DR's Avatar
Default Re: Was changing my coolant and uh oh!!!!! (type r 01-1063)
Grocery store. I highly doubt an autopart store would carry water, let alone distilled water.
Old Jul 22, 2002 | 05:48 AM
RaVAGE00's Avatar
New User
Default Re: Was changing my coolant and uh oh!!!!! (GZR4DR)
You have to be fricken joking?!?!?! where can you get distilled water?
92blm92
31
Nov 7, 2017 03:48 PM
crxaddikt
Mar 25, 2014 11:00 PM
89sparks
May 14, 2008 07:38 AM
daisymae
Honda Civic (2001 - 2005)
35
Nov 5, 2007 06:38 PM
ALLMOTORD16Z6
May 20, 2005 03:27 AM
