i am stumped and need help....
Old Jul 29, 2008 | 12:55 PM
brother30's Avatar
Default i am stumped and need help....
i have the stock d-series. it wont run. I have a code 16 which is fuel injector fault. i replaced the throttle body and it did nothing. It has a new ignition coil, ignition control module. but when i put new plugs and wires on it it ran good for about three blocks then shut down. it turns over and you can hear compression but no fire. any thoughts?
Old Jul 29, 2008 | 01:02 PM
redef90si's Avatar
Default Re: i am stumped and need help.... (brother30)
make sure the fuel injector clips are tight.may be your resistor box?gl
Old Jul 29, 2008 | 03:00 PM
vtecb18c's Avatar
Default Re: i am stumped and need help.... (redef90si)
you changed everything for spark not fuel...make sure your getting power to your injectors...try a different set and go from there
Old Jul 29, 2008 | 06:30 PM
Crx Jimmy's Avatar
Default Re: i am stumped and need help.... (vtecb18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb18c &raquo;</TD></TR><TR><TD CLASS="quote">you changed everything for spark not fuel...make sure your getting power to your injectors...try a different set and go from there</TD></TR></TABLE>
I think he did swap injectors he said he changed the throttle body, he is probably dpfi which is throttle body injection.
Old Jul 31, 2008 | 05:46 PM
beige89civic's Avatar
* B A N N E D *
Default Re: i am stumped and need help.... (Crx Jimmy)
Replace main relay assembly 3900-sh3-003
DEL HATCH
Jan 28, 2008 04:59 PM
a.nalazek
Aug 29, 2006 06:46 PM
SonicBluDC2
Jan 14, 2006 05:09 AM
jackzzz
Jun 6, 2004 07:32 PM
Bert
Feb 16, 2002 10:37 AM
