TB question
Old Jul 29, 2008 | 10:40 AM
Redemption's Avatar
Default TB question
So I have a OBD2 B18B in my car and I wanted to put in a TB from a GSR or ITR. I know that they will fit. I have searched and found the answer to that. But the question I still have unanswered is, Will a OBD1 TB work on a OBD2 engine? Also what is the size of a GSR TB?
Old Jul 29, 2008 | 11:18 AM
Brice.Hayden's Avatar
Default Re: TB question (Redemption)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redemption &raquo;</TD></TR><TR><TD CLASS="quote">So I have a OBD2 B18B in my car and I wanted to put in a TB from a GSR or ITR. I know that they will fit. I have searched and found the answer to that. But the question I still have unanswered is, Will a OBD1 TB work on a OBD2 engine? Also what is the size of a GSR TB? </TD></TR></TABLE>
make sure you get the gsr gasket or it will leak. I would use the obd2 LS TPS also. i think its a 60mm i could be wrong.
Old Jul 29, 2008 | 06:49 PM
Fuchueson's Avatar
i believe the TB size is 62mm stock for GSR
Old Jul 29, 2008 | 11:07 PM
Redemption's Avatar
So its bigger than a SI's tb if its 62 because I know that SI tb is 60 and I figured that a GSR would be pretty much the same.
p3tey2
May 28, 2015 06:46 AM
mfisher1987
Jul 24, 2012 06:38 PM
vntperformance
Aug 24, 2006 04:17 AM
strongarm1731
Jan 15, 2006 07:42 PM
