grounding wires to bare metal or over paint live in NY and have salted roads and rust problems
Old Jul 29, 2008 | 10:26 AM
namewasdallas's Avatar
Default grounding wires to bare metal or over paint live in NY and have salted roads and rust problems
so i just orderd a nrg grounding kit, now everyone says to file out the paint at any of the ground spots, well i live in new york and i think if i got bare metal then my ground wire to it im gonna start to rust and then it wont be as good or good at all.
my question is should i just ground over the paint or clean the paint off the spot on the body im gonna ground to?
and which bolt on the intake manifold and where on the TB should i ground to? ill use search for these but just figured id add them in but the paint deal im not sure new york has wicked salted roads in the winter.
Old Jul 29, 2008 | 10:32 AM
JdelMsolG's Avatar
Default Re: grounding wires to bare metal or over paint live in NY and have salted roads and rust problems (
i think you're over analyzing this man.
Just ground over the paint.
Old Jul 29, 2008 | 10:39 AM
d357r0y's Avatar
You could sand back the paint and use some dielectric grease on the mating surface to keep it from rusting.
Old Jul 29, 2008 | 11:30 AM
jkiser's Avatar
I would grind it down then paint over it or use some silicone after you get everything mounted down.
Old Jul 29, 2008 | 01:15 PM
thesmogman's Avatar
yes, die-electric grease or sillycone will work too.
dirty19
Paint and Body
Mar 31, 2011 09:28 PM
GoLowDrew
Paint and Body
May 16, 2010 05:21 AM
FishyMan
Paint and Body
Feb 28, 2009 06:17 PM
vdub08
Nov 4, 2004 04:38 PM
huntarrr
Sep 21, 2004 11:30 AM
