Hey I Need Help!!!
Old Jul 29, 2008 | 09:25 AM
SIef9's Avatar
Default Hey I Need Help!!!
I have a ef with a 95 jdm d15b vtec it runs great the only problem is when i punch the gas pedal all the way in it bogs no matter what gear but as long as its over 3000 rpm it bogs. Can anyone help.
Old Jul 29, 2008 | 09:27 AM
wiZCo's Avatar
Stouts 'n' Scotch
Any codes? Timing correct? What ECU are you running?
Old Jul 29, 2008 | 09:29 AM
SIef9's Avatar
Default Re: (wiZCo)
i took it to the guy that put it he said no codes and im running a p28 the timing is good
Old Jul 29, 2008 | 10:25 AM
90teg91hatch's Avatar
Default Re: (SIef9)
check your spark plugs, may have a lose one, or they are fowled... i had a similar problem... that fixed it right up..
Old Jul 29, 2008 | 11:13 AM
jdmd15crx's Avatar
Default Re: (90teg91hatch)
check ur tps sensor
Old Jul 29, 2008 | 11:25 AM
efhatch_311's Avatar
Default Re: Hey I Need Help!!! (SIef9)
i had a b18a in my ef and when my tps sensor was unplugged thats exactly what it would do. im not positive but you could check ur tps on ur motor.
Old Jul 29, 2008 | 11:26 AM
Aristotle's Avatar
Check injectors, I had same problem and first cylinder injector was bad.
Default Re: Hey I Need Help!!! (efhatch_311)
yeah that too... tps and map sensor may be backwards too... they are the same plugs i had the same mistake too...
Old Jul 29, 2008 | 01:11 PM
jdmd15crx's Avatar
Default Re: Hey I Need Help!!! (90teg91hatch)
if its cutting back then ur ecu could be in safe mode
Old Jul 30, 2008 | 08:43 AM
SIef9's Avatar
Default Re: Hey I Need Help!!! (jdmd15crx)
do you know how i can get it off safe mode?
Old Jul 30, 2008 | 09:01 AM
JustAnotherRex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmd15crx &raquo;</TD></TR><TR><TD CLASS="quote">if its cutting back then ur ecu could be in safe mode</TD></TR></TABLE>
If it was in limp mode it would be throwing a code?
Someone can correct me if I'm wrong, but I've never heard otherwise.
Old Jul 30, 2008 | 10:04 AM
Default Re: Hey I Need Help!!! (JustAnotherRex)
yup limp mode im pretty sure it would throw a code..
Old Jul 30, 2008 | 10:09 AM
_Keith_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90teg91hatch &raquo;</TD></TR><TR><TD CLASS="quote">yeah that too... tps and map sensor may be backwards too... they are the same plugs i had the same mistake too... </TD></TR></TABLE>
If thats the case should be throwing a code!
Old Jul 30, 2008 | 11:13 AM
jdmd15crx's Avatar
Default Re: Hey I Need Help!!! (_Keith_)
could be ur crank position sensor i had that same problem i had to get a new dizzy. idk why you wouldnt be throwing a code tho.
Old Jul 30, 2008 | 11:20 AM
well he said he bought a new distributor.. problem still wasnt solved..
Old Jul 30, 2008 | 11:29 AM
jdmd15crx's Avatar
could be a wiring or ground problem
Old Jul 30, 2008 | 11:42 AM
traxxasx's Avatar
Did you switch the 2 outer wires around on the tps.
MMMGIRL
Apr 22, 2012 10:21 AM
chope045
12
Dec 12, 2010 06:36 AM
Sticky2K
Aug 17, 2009 11:16 AM
jordan_civic
May 30, 2008 10:35 PM
Chico90hb
Oct 5, 2005 09:42 AM
