PE timing belt update! Interesting trip to Charlotte
Old Jul 21, 2002 | 05:58 PM
VTHokie's Avatar
Default PE timing belt update! Interesting trip to Charlotte
Finally got to check out what was wrong with the pe timing belt. Here is the original post. https://honda-tech.com/zerothread?id=219072 It turns out that it was infact a bad installation, and that the belt was rubbing against the lower timing belt cover. It was rubbing so hard, it actually melted the side of the cover, and was also rubbing against one of the support tabs and melted that too. Willard checked out the tension, and determined that is wasn't tight enough, which was probably making it flap around and hit the cover. We inspected the old belt (only 2k miles on it), and it was still in great shape, other than the markings, i probably can still use it, but i decided not too cause we already took it out. New pe belt is in now with the correct tension, and the car sounds so much better at start up, no more chattering. But still have that jamn lumpy god damn goodness . Anyway, just wanted to update you guys, PE belts are good , buy them from Leo at JDM spec perf.
On a side note, i had quite the excursion down to charlotte. I was cruising down on i77 going ~ 80-90 mph (gotta love the 70mph speed limit), and 23 miles outside of charlotte, my car just dies. At this point im freaking out, thinking my timing belt snapped. Pulled over to the side of the road and cursed for 2 1/2 straight hours. So i roll over to will's place with with a bling bling tow truck @ 2 am in the morning and $115 lighter. Next day we check out the engine, timing belt was still intact, but loose. Will check the exhaust cam, and rotates its, seeing if the valves are in good shape. Checks out alright. Then he checks the intake cam. CRUNCH CRUNCH!! At this point im freaking out, thinking it was my valves. Will sets everything straight, corrects the tension and we try to start the engine, and the beotch would still not turn over. Will, being the great car investigator he is, checks the distributor and finds this sheet. Turns out my rotor button in my distributor just failed, thus not allowing my sparks plugs to work, and it also focked up my distributor cap. God jam 30 dollar parts will get you every time!! . Anyway, all is well now, so don't be hesitant to buy those pe belts, they are good sheet!
Eric
[Modified by VTHokie, 10:09 PM 7/21/2002]
Old Jul 21, 2002 | 06:15 PM
StinkyTofu's Avatar
Default Re: PE timing belt update! Interesting trip to Charlotte (VTHokie)
*Phew* Its finally good to hear something positive about timing belts. I'm glad the toda B's weren't the culprit. Its strange that honda can't even install a timing belt...
Old Jul 21, 2002 | 06:46 PM
Willard's Avatar
and to think... I was sober while working on your car this time....
Will
Old Jul 21, 2002 | 06:56 PM
VTHokie's Avatar
Default Re: PE timing belt update! Interesting trip to Charlotte (Willard)
Yep, no drinking that day, it was focking 2000 degrees in that jamn garage of yours , thank god for kool aid, it saved the day!
Eric
Old Jul 22, 2002 | 07:27 AM
owen_the_soyboy's Avatar
oh jeebus, who wants to hear a CRUNCH CRUNCH!
happy ending yes? no?
YES.
Old Jul 22, 2002 | 08:16 AM
Black R's Avatar
25 Year Member
.....glad to hear everything is ok!
*whew*
I installed my PE belt this past saturday around 4am (don't ask) and made sure it was tight as ****. PE =
My oem/ stock belt was fine too - just looked a little weird. But I'm not running a cut valve cover anymore... too much debris in there fo sho!
Old Jul 22, 2002 | 09:37 AM
ITRinEJ1's Avatar
Default Re: PE timing belt update! Interesting trip to Charlotte (Black R)
glad to see everything worked out for ya eric
Old Jul 22, 2002 | 10:21 AM
VTHokie's Avatar
Yeah, im about to switch to a closed valve cover also, and just keep the cut one for when i go tuning.
Good thing is the old pe belt is not going completely to waste, selling it to somebody for some liquor!
Leo, pe belt is good sheet
Eric
[Modified by VTHokie, 2:27 PM 7/22/2002]
Old Jul 22, 2002 | 10:56 AM
GraphiteAccord's Avatar
haha, i did the EXACT same thing in my car. i was like "****, i just blew it up" cause the car just died on my trip to 8K in 3rd gear. towed home (for free ) pulled the cap, rotar was in 20 pieces!
Old Jul 22, 2002 | 11:15 AM
VTHokie's Avatar
Default Re: PE timing belt update! Interesting trip to Charlotte (GraphiteAccord)
Really? That is interesting, is this a common thing? How many miles did you have on your rotor?
Eric
Old Jul 22, 2002 | 03:09 PM
00MRSi's Avatar
Willard = Nice job..
Old Jul 22, 2002 | 03:16 PM
EagleR's Avatar
I would have MADE SURE you drank, so I'd know everything would work properly when finished!
Old Jul 22, 2002 | 03:19 PM
01PYITR's Avatar
Willard good save!
Old Jul 22, 2002 | 04:54 PM
Hooch'n's Avatar
Default Re: PE timing belt update! Interesting trip to Charlotte (01PYITR)
Nice pics...Nice meeting you VTHokie! Pics don't do it justice when you see it actually come off the car...
Old Jul 22, 2002 | 05:16 PM
Black R's Avatar
25 Year Member
Eric
Yeah, that's an ultra-common thing. Check your rotor button every 10k miles max... Or get a direct coil ignition.....
Old Jul 22, 2002 | 05:49 PM
VTHokie's Avatar
Wow, hehe, wish i knew that this past weekend. Chit, those rotor buttons are so jamn cheap, i minus well just replace it every 10k miles anyway.
Andy it was great meeting you too, hope you enjoyed riding the slow azz si.
Eric
Old Jul 22, 2002 | 06:22 PM
Hooch'n's Avatar
I didn't say it was slow did I? Hahahaha
Andy: If I hadn't gotten the R...I'd have an Si B16A Toda Killa!
All you need now is a set of 22's...
Old Jul 23, 2002 | 07:21 AM
VTHokie's Avatar
Default Re: PE timing belt update! Interesting trip to Charlotte (8400-RPM)
Haha, hey Andy, did anyone ever tell you, that you look alot like that guy off american pie
Sorry d00de, i couldn't resist!
Eric
Old Jul 23, 2002 | 07:29 AM
Brian*'s Avatar
he looks like Eugene Levy?!?!
Brian
Old Jul 23, 2002 | 07:35 AM
VTHokie's Avatar
Default Re: PE timing belt update! Interesting trip to Charlotte (Brian*Black99Si)
He looks like Jason Biggs yo! Well at least according to the local Arby's *****.
Edic
Old Jul 23, 2002 | 07:47 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Ken. Did you do the Spec C's or no?
HyperFlow
Aug 2, 2010 01:46 PM
frankyp
Jan 22, 2008 08:14 PM
honda_joe
13
Oct 13, 2004 03:39 PM
Imprezn
May 6, 2003 01:36 PM
