Argon Regulator Recommendations
Old Jul 29, 2008 | 08:02 AM
Jasper_db1's Avatar
Default Argon Regulator Recommendations
I'm a beginner and have a Miller Dynasty 200 and want to start practicing soon but need to get a tank and regulator. Are there certain things to look for? do you guys have recommendations? I'm purely a weekender working on little brackets and exhausts for my motorcycles.
Old Jul 29, 2008 | 12:47 PM
dfoxengr's Avatar
Default Re: Argon Regulator Recommendations (Jasper_db1)
then the cheapies will be fine. I like the flowmeters that have the sightglass with a suspended ball in them though. But I still use the cheap one for personal home use.
Old Jul 29, 2008 | 03:14 PM
x SPY x's Avatar
Default Re: Argon Regulator Recommendations (dfoxengr)
I bought a Victor regulator recently that I use on my back purge setup, I'd recommend it good quality unit.
Old Jul 29, 2008 | 05:07 PM
k24em2's Avatar
Default Re: Argon Regulator Recommendations (x SPY x)
Old Jul 29, 2008 | 08:01 PM
ssmdc2's Avatar
Default Re: Argon Regulator Recommendations (k24em2)
Link to where we can get the one in the pic??
Old Jul 29, 2008 | 10:22 PM
ROTARY's Avatar
VICTOR - http://store.cyberweld.com/viredfm150du.html
SMITH - http://store.cyberweld.com/smduflre30se.html
Old Jul 30, 2008 | 07:36 PM
89civicdx's Avatar
Default Re: (ROTARY)
Do you guys use tape on your threads I can never get mine to seal without a **** load of tape
Modified by 89civicdx at 8:56 PM 7/30/2008
Old Jul 30, 2008 | 07:59 PM
ROTARY's Avatar
Default Re: (89civicdx)
you shouldn't need teflon because the threads don't do the actual sealing, check the tip of your hoses to make sure that the sealing surfaces aren't dented.
Old Jul 30, 2008 | 08:15 PM
89civicdx's Avatar
Ya that's what I thought but the thing never sealed from out of the box, so I wasn't really sure. I've had it for a long time with different tanks and it would never seal without tape. I guess I'll try a new one and see. Thanks
Old Jul 30, 2008 | 08:31 PM
ROTARY's Avatar
i mentioned that because i once dropped a hose and dented the tip... never sealed again, did you check the sealing surface on the tank valve?
Old Jul 30, 2008 | 08:46 PM
89civicdx's Avatar
You mean on the tank or reg? I've had many different argon tanks so those aren't the problem....it's getting the big reg fitting to seal with any tank...It looked ok to me but let me check it again as maybe I did dent it...I never thought really about that. Without the tape I could just tighten it as much as it would go and it would just make a real quiet hiss.
I'll pull it off in the morning...lol damn tape
thanks for the help
Old Jul 30, 2008 | 09:18 PM
ROTARY's Avatar
I'm sorry i meant the regulator
mkehler
Welding / Fabrication
13
Jul 11, 2009 10:29 PM
sup3rd
Lighting
11
Jun 25, 2008 04:44 PM
LifeMage
Feb 4, 2008 11:00 PM
96supercharged
36
Jan 23, 2008 02:17 PM
