Suspension & Brakes Theory, alignment, spring rates....
Coil spring position on plate:
Old Jul 29, 2008 | 04:51 AM
blaak-crx's Avatar
Default Coil spring sitting half way on adjustable sleeve plate: safe?
I have Konis with an adjustable plate. I am currently using H&R 60 mm ( 2 3/8")coil spring. I want to reduce the spring rate and the shop (store) has the Eibach 2.5" coils available on the shelf. I did a test fit on the shocks and the Eibach sits "half way" on the plate (see photo). And when I push the whole coil on one side, it will sit near the edge of the plate. Is this safe for the track? I know 1/8" difference is small but I am afraid that having only half of the coil on a contact patch can damage my plate.
Modified by blaak-crx at 5:34 AM 7/30/2008
Old Jul 29, 2008 | 08:51 AM
VTECIntegra9's Avatar
See if you can make an adapter that will fit the OD of the sleeve and the ID of the desired spring. I'm having a similar problem on my upper mount - going to make some spacer/adapters. If they're not sitting on it fully, then they're probably going to rattle around and shift. Since it's taken apart I would fab up a piece that will make everything slip together neatly and be fully seated.
I made that mistake and now my car's out of commission again.
Old Jul 30, 2008 | 12:51 PM
blaak-crx's Avatar
Default Re: (VTECIntegra9)
More picts:
On the left side of the coil is the area of contact on the ajustable ring:
This is when I push the coil on one side of the sleeve:
Old Jul 30, 2008 | 01:23 PM
hmm i wouldnt trust that for track use. Are you able to get a different adjuster nut or make something?
Old Jul 30, 2008 | 03:36 PM
Targa250R's Avatar
be professional
Default Re: Coil spring sitting half way on adjustable sleeve plate: safe? (blaak-crx)
Why not use 2.25" ID ERS springs instead?
Old Jul 30, 2008 | 06:06 PM
blaak-crx's Avatar
Default Re: Coil spring sitting half way on adjustable sleeve plate: safe? (Targa250R)
I know. Just that the shop had that model on the shelf and the next Time Attack is soon. Don't really feel like waiting a month to get. Anyways, I will be returing those and order the 2.25 ID.
Old Jul 30, 2008 | 07:43 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
If you are local stop by and we can throw some 2.25" to see if they fit ok. They should....
Old Jul 30, 2008 | 08:40 PM
blaak-crx's Avatar
Default Re: Coil spring sitting half way on adjustable sleeve plate: safe? (vtecvoodoo)
For sure the 2.25" will fit (I mesured the OD of the sleeves). Unfortunately, I am up north (Canada).
maxogsr
Suspension & Brakes
Feb 12, 2010 09:33 AM
xxdevilzeroxx
Suspension & Brakes
Feb 11, 2010 08:28 PM
Killer Kham
Suspension & Brakes
Dec 18, 2008 06:51 AM
