need some advice front brake upgrades
Old Jul 28, 2008 | 07:51 PM
Nutnwrench's Avatar
Default need some advice front brake upgrades
I have a 91 CRX HF daily driver/ xcross once a month or so and I'm going to need a total front brake job soon, pads rotors brake hoses wheel bearings, and I would like to upgrade a little and I'd like some advice on what I should do and brands ei: steel hoses, hawk pads, drilled slotted rotors etc. This will be a budget build but I will pay for quality so long as it's not just bling. I also don't really have access to a torch or press so I won't be doing some crazy big brake upgrade with custom mounts and so forth. Thanks in advance everyone.
Old Jul 28, 2008 | 07:59 PM
EFstyle's Avatar
Default Re: need some advice front brake upgrades (Nutnwrench)
i reccomend going to a junkyard and picking up a set of DA front knuckles and throwing those on, new Nissin calipers, rotors, pads, then its up to you ow far you wana go... I replaced EVERY peice in the wheel well down to the juts and bolts and i think its worth it
Old Jul 28, 2008 | 08:46 PM
Nutnwrench's Avatar
Default Re: need some advice front brake upgrades (EFstyle)
would i still be able to use the same axles with the DA hubs? I haven't swapped much so my first feeling is a DA hub bore is large than my CRX
Old Jul 28, 2008 | 08:47 PM
Eazy-EF's Avatar
fast brakes makes some pretty sweet upgrade kits
Old Jul 29, 2008 | 09:26 AM
Nutnwrench's Avatar
Default Re: (Eazy-EF)
Thanks Eazy they do make some nice kits. If i went to an 11in rotor would that be a DA rotor and would it fit with 14 or 15in rims?
Old Jul 29, 2008 | 09:41 AM
Nutnwrench's Avatar
Default Re: (Nutnwrench)
Any thoughts on what to do for brake hoses? I've searched some and it sems like stainless steel lines cause more trouble than they are worth.
Old Jul 29, 2008 | 10:17 AM
CRX Toad's Avatar
https://honda-tech.com/zerothread/1508680 look under "Suspension & Brakes"
I run standard lines, I have felt no difference in my pedal with SS line and they are a wear item as much as people think they aren't. To stop better there are better ways to spend the money.
Old Jul 31, 2008 | 09:52 PM
Nutnwrench's Avatar
Default Re: need some advice front brake upgrades (CRX Toad)
Thanks alot. I read through the 11In and 10In brake upgrades and i feel like my eyes are going to bleed but its great stuff. thinking on doing the 10in swap but Since I have a HF would the accord calipers (17CL15vN) bolt up or would i have to find a different knuckle?
Old Jul 31, 2008 | 10:13 PM
guysensei's Avatar
I just came upon this great article i hope it helps you
http://www.ef-honda.com/ben/EFhybridsus.php
Old Aug 1, 2008 | 11:24 AM
Nutnwrench's Avatar
Default Re: need some advice front brake upgrades (guysensei)
more great information thank you. It still didn't answer my question though if i can do the milled caliper brackets and install it on my HF. fastbrakes says his bracket will mount right up to any knuckle so that would make me think that the HF knuckle would work for this. Please someone correct me if I'm wrong.
Old Aug 1, 2008 | 12:20 PM
JesseCRX's Avatar
Best advice I ever took was
BREMBO BLANKS
Hawk Pads
SS Brake Lines
Old Aug 1, 2008 | 02:45 PM
Nutnwrench's Avatar
Old Aug 1, 2008 | 02:52 PM
Red_ED8's Avatar
Default Re: need some advice front brake upgrades (JesseCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JesseCRX &raquo;</TD></TR><TR><TD CLASS="quote">Best advice I ever took was
BREMBO BLANKS
Hawk Pads
x2 don't waste your money on drilled and slotted rotors, there just bling
Old Aug 1, 2008 | 03:51 PM
Nutnwrench's Avatar
Default Re: need some advice front brake upgrades (Red_ED8)
yeah I want to maintain some long term reliability and all i've ever heard about drilled and slotted was your pad life goes down the tubes for a marginal braking gain.
Old Aug 1, 2008 | 04:14 PM
Tyson's Avatar
xcross?? autocross?
what class?
Old Aug 1, 2008 | 08:07 PM
E-AT_me's Avatar
Default Re: need some advice front brake upgrades (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">xcross?? autocross?
what class?</TD></TR></TABLE>
CHECK YOUR RULES!!! what you do could bump you to a different class. it doesn't matter if you aren't competitive. you may be one day..
Old Aug 3, 2008 | 01:16 PM
RockingRex90's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nutnwrench &raquo;</TD></TR><TR><TD CLASS="quote">It still didn't answer my question though if i can do the milled caliper brackets and install it on my HF. fastbrakes says his bracket will mount right up to any knuckle so that would make me think that the HF knuckle would work for this. Please someone correct me if I'm wrong.
Anyone have a answer to this? I'm curious about this swap and I have a HF also. Will the milled calipers mount up to the HF knuckle?
Old Aug 3, 2008 | 03:44 PM
Default Re: (RockingRex90)
Bump for answer
Old Aug 3, 2008 | 10:52 PM
Tyson's Avatar
the knuckle of the HF is the same as DX and Si.
its just the hub that is smaller. and the caliper and rotor that mounts on to it.
so therefore, any caliper that will fit the DX or Si knuckle will fit the HF knuckle.
mrdeadman
Oct 5, 2005 03:31 PM
faSHOwidIT
Apr 18, 2005 02:06 AM
clin20
Jun 7, 2004 08:30 AM
YipMan_Style
Oct 29, 2002 08:55 AM
crxzc
Jul 15, 2002 03:07 PM
