2001 b18c5 swap FS PA
official honda whore
2001 itr swap (from my 2001 ITR)
willing to trade for swap parts for k20 into dc2
3,000 OBO for all of it or:
complete head (head, dizzy, i/m and tb and vc) =1,100 obo
head: 900 (2001 itr head, all original, cams included)
dizzy: 150
intake manifold with tb: 250
valve cover: 100
harness: 150
starter: 50
alternator: 50
trans: 850
block: 600
shift linkage: 100
axles: 140
ecu: 150
flywheel/clutch: 100
block needs rings, trans has slight grind if you shift at redline into 3rd gear periodically
will be available to be shipped or picked up on august 11th
Modified by EARLdaSQUIRREL at 6:20 PM 7/30/2008
Modified by EARLdaSQUIRREL at 6:28 PM 7/30/2008
Modified by EARLdaSQUIRREL at 6:55 PM 7/30/2008
Modified by EARLdaSQUIRREL at 12:08 AM 8/2/2008
dizzy: 150
valve cover: 100
harness: 150
starter: 50
alternator: 50
trans: 850
block: 600
shift linkage: 100
axles: 140
ecu: 150
this is earldasquirrel on friends name:
added a cap of oil to each cylinder redid the compression check and they shot right back up which means its the rings not the valves
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">More problems with your R?</TD></TR></TABLE>
ha ha not a big problem, just a good reason to go K like i wanted to
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by benchmade »</TD></TR><TR><TD CLASS="quote">
thanks
</TD></TR></TABLE>thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EARLdaSQUIRREL »</TD></TR><TR><TD CLASS="quote">pm's replied</TD></TR></TABLE>
