Loss Of Clutch Pressure After Motor Swap
Old Jul 28, 2008 | 06:30 PM
kra4718's Avatar
Default Loss Of Clutch Pressure After Motor Swap
So I did a motor swap in my car and my clutch worked fine before the swap but now after the swap my pedal has no pressure at all. It will be all the way out and then you tap the pedal and it goes all the way to the floor without any effort and stays in. Same thing on the way out. Please Help
Old Jul 28, 2008 | 07:12 PM
LSVTECTEG18's Avatar
Default Re: Loss Of Clutch Pressure After Motor Swap (kra4718)
Did you swap transmissions during your swap? Like from your old motor to your new one.
If so my bet would be slave master cylinder. It really easy for it to over extend or even get the fork off track. When I did my swap mine wasn't seated all the way and I got air in my system. You could also try bleeding the system if all else fails just to check for air. goodluck
Old Jul 28, 2008 | 07:17 PM
__oversea's Avatar
did you bleed the line at all??
Old Jul 28, 2008 | 07:21 PM
LSracing94's Avatar
Default Re: Loss Of Clutch Pressure After Motor Swap (__oversea)
sounds like someone stepped on your clutch before you installed your new motor and it killed your slave cylinder
Old Jul 30, 2008 | 06:48 PM
kra4718's Avatar
Thank you guys. I had been figuring it was my slave cylinder because there were a bunch of people that were around my car during the swap and im sure someone got in and pushed my pedal. Yet again thank you guys. Now i just gotta get another lol.
Old Jul 30, 2008 | 10:44 PM
JDM_CRX_PLEASE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kra4718 &raquo;</TD></TR><TR><TD CLASS="quote">Thank you guys. I had been figuring it was my slave cylinder because there were a bunch of people that were around my car during the swap and im sure someone got in and pushed my pedal. Yet again thank you guys. Now i just gotta get another lol.</TD></TR></TABLE>
thats why when i do a motor swap its just me and 1 or 2 other persons. if noone else is helping then i dont let them around... thats how tools and parts get lost i hate thattt
Old Jul 31, 2008 | 07:22 AM
Horseofcourse's Avatar
Default Re: Loss Of Clutch Pressure After Motor Swap (JDM_CRX_PLEASE)
Did you even try bleeding the lines?
Old Aug 1, 2008 | 04:46 PM
kra4718's Avatar
Default Re: Loss Of Clutch Pressure After Motor Swap (Horseofcourse)
i cant bleed them because i have no clutch pedal pressure. And when i try to bleed them only drops off a couple drops.
Old Aug 1, 2008 | 05:57 PM
it takes two people to properly bleed a clutch line. one to operate the the valve and to add more fluid.
1. Fill It
2. Close the valve
3. Have some pump the pedal to the floor and all the way out.
3 1/2. Hold the pedal to the floor
4. Open the valve to release the air
5. Add more fluid if needed.
Repeat the process 4 times till you start to feel pressure. you should repeat the process 10 plus times to get proper feel.
trevan
Dec 31, 2017 09:46 PM
mr_romero91dc2
Feb 14, 2014 12:17 PM
FO SHO
16
Jun 2, 2011 08:52 AM
wadecarter89
Dec 23, 2006 08:10 PM
r1de4life
11
Jun 11, 2006 07:17 PM
