Timing belt 1990 Acura Intergra.. Skips, on intake cam!!!
Old Jul 28, 2008 | 04:23 PM
kimbrough187's Avatar
Default Timing belt 1990 Acura Intergra.. Skips, on intake cam!!!
I have a 90 Acura integra, i bought a new timing belt kit, and also replaced the water pump. The problem is after setting the timing, i start the car it runs strong for the first couple of minutes (3-4) and then the intake cam jumps. After taking it all back apart, the exhaust mark is correct, the crank mark is in place, but the intake is off. i wanna know what could cause this problem?????
Old Jul 28, 2008 | 07:50 PM
norconex's Avatar
Default Re: Timing belt 1990 Acura Intergra.. Skips, on intake cam!!! (kimbrough187)
improper tension on the belt
not sure why this question is in this section though
Old Jul 28, 2008 | 07:57 PM
Default Re: Timing belt 1990 Acura Intergra.. Skips, on intake cam!!! (norconex)
Where should i put it? this is like my first time doin the from thing.
Old Jul 29, 2008 | 08:01 PM
HiProfile's Avatar
It should have been put in tech/misc.
Did you tension the belt properly, or just guess? You are supposed to have the tensioner bolt slightly loose, turn the crank pulley a certain amount (check service manual), then tighten that bolt.
Old Jul 29, 2008 | 08:12 PM
Default Re: Timing belt 1990 Acura Intergra.. Skips, on intake cam!!! (HiProfile)
yea, i used a pry bar to adjust the tensioner! then i locked it down. but it still skips. i wonder if i have something put on backwards. checked all the parts and they match up to the ones thats on the car.
Old Jul 30, 2008 | 08:50 AM
TheWickedOne's Avatar
Tensioner, mixed cam caps, or cam caps backwards.. can cause timing belts to jump
Old Jul 30, 2008 | 09:22 PM
Default Re: Timing belt 1990 Acura Intergra.. Skips, on intake cam!!! (TheWickedOne)
When you say cam caps, your meaning the ones that hold the cam down... or are you talking about the ends?
Old Jul 31, 2008 | 06:16 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kimbrough187 &raquo;</TD></TR><TR><TD CLASS="quote">When you say cam caps, your meaning the ones that hold the cam down... or are you talking about the ends?</TD></TR></TABLE>
Correct.
Old Jul 31, 2008 | 09:21 PM
i am thinkin all thats correct. i bought a timing belt kit. how do you guys feel about those?
danteisme
Apr 1, 2016 12:15 AM
WhiteOnRice
Nov 11, 2012 09:31 AM
Singha83
Jun 30, 2012 11:27 PM
98GSR-Turbo
Feb 11, 2008 02:14 PM
