I think my air conditioning compressor is leaking.... can that be fixed?
I have a 1990 honda crx with a b16. I decided to put my a/c back in so I put everything back in and the compressor didn't work so bought a new compressor, and installed it and ran the system for about a week and while driving home I heard a loud noise coming out of the engine bay (it sounded like air leaking out of a high pressure system) so I stopped didnt see anything then continued driving and then the a/c started to stop working and got hotter and hotter. I tried putting a new can of R134a in and it just came right out sounded like it was coming out of the compressor so I got a can of leak detector the one thats red dye and put that in and didnt see anything but heard it coming out of the compressor so then I put another can of 134a in and still didnt see the red but I heard it coming out... Is there any gaskets or seals on the compressor that could be leaking I mean it ran great for a week and was at the perfect pressure when I checked it but all of a sudden it stopped any ideas? Dont want to have to replace the compressor again they are expensive
I bought an A/C O ring kit and it had had seals that supposedly went in the compressor. I haven't got that far yet. Sounds like you blew one of those. I got my kit from advance auto for about $12.00 It has all the seals you could use.
there is a pressure valve on the back of the sandens that goes bad frequently (at least from what I have read and been told by dealer mechs) When you remove the 3 rear bolts and remove the cover you can see it. It is spring loaded. Mine started leaking from that very spot.
marqoid
10
Jun 28, 2013 04:41 PM
90jdmcrxdude
Jul 27, 2008 07:09 PM
