transmission problem.. rebuild or computer problem?
Old Jul 28, 2008 | 02:41 PM
nuttyvtec's Avatar
Default transmission problem.. rebuild or computer problem?
Hi,
I have an ej1 94' with d16z6 and automatic transmission. HEY! i hate automatic. I have b16 head, b20 block, and gsr tranny in my garage that I am going to swap, but not enough in fund to buy wiring, ecu, motormounts, and etc. Right now, d16z6 for now as a daily driver. Ok... the first transmission was shifting late, when ran with let go brake, it does... arugg.. and when start and go, it goes very slow reponse. i dont know how to explain. It kinds of shift hard, so I switch the another transmission that had only 85k. Now it kind of the same like before, but better than old one. the only problem is it have slow reponse. when i push full gas, it should go faster, but mine is not... wondering why?? is that computer is bad or what?!?!?! need help! pllleeeaaassseee. thanks!
Old Jul 28, 2008 | 03:22 PM
john666's Avatar
Default Re: transmission problem.. rebuild or computer problem? (nuttyvtec)
what type of atf do you use. ?
Old Jul 28, 2008 | 03:53 PM
djsire's Avatar
Default Re: transmission problem.. rebuild or computer problem? (john666)
che your trsnny fluid.
also chek the trany shift =cable located on the throttle boddy
blue_egsi
Apr 16, 2012 04:33 PM
lovelove
Dec 11, 2009 07:32 AM
93hondacivic
Oct 7, 2008 09:57 PM
AgentofDarkness
Jun 3, 2006 07:47 AM
Dougs96SI
Dec 14, 2004 12:47 PM
