fuel pressure settings, help
im trying to set my fuel setting good. i have 310cc injectors, AEM FPR, and fields SFC, im NA right now running 9:1 compression(about to boost..lol) should i just leave the fields zeroed out, and what should i set my fuel pressure guage at?? thanks, remember im not boosting yet. its NA right now?
As low as you can. I don't know anything about the Fields, does it control fuel? If it does you can use it instead of the FPR, but you need to do something. If you can get pressure down to about 35psi (with vacuum hose off) it should run good.
