help about shock!! reallyy need it. by today =(
Old Jul 28, 2008 | 12:21 PM
caibang88's Avatar
Default help about shock!! reallyy need it. by today =(
will a honda civic shock from a 96 to 2000 civic fit m 92-95 civic hatch? thanks.
Old Jul 28, 2008 | 12:23 PM
Relic1's Avatar
front - yes
rear - if you really need it to, yes.
the rear lower arm mount is narrower on the 96-00 civic than the 92-95 civic, either spread it or grind down the bushing in the arm.
Old Jul 30, 2008 | 11:10 PM
caibang88's Avatar
Default Re: (Relic1)
oh thanks is it going to be ok if i instal the rear?? anything going to happen????.
Old Aug 4, 2008 | 01:15 AM
Xscort's Avatar
not threadjacking, just trying to get a more elaborate answer....grind down as in i can use a dremel and widen the bushing??
Old Aug 4, 2008 | 06:51 AM
Relic1's Avatar
EKs on an EG, or EGs on an EK has been done many times. I haven't heard of anyone having any problems. Other than the original fitment issue of course.
a drumel would take a while, but yes grind down the shock bushing, narrowing it... so the shock will fit over it. It's really obvious when you see it.
NOTE: some aftermarket companies use spacers in the EK setup, that way they can use the same shock for the EKs and EGs. The spacers make the narrower EK lower mount work on the wider shock.
Old Aug 4, 2008 | 07:01 AM
batallic's Avatar
u trim the bushings until it fits for the rear, i got 96-00 shocks on my 93 my ex all around
Old Aug 4, 2008 | 08:13 AM
Xscort's Avatar
ok thanks preciate the answer, although wasnt my thread lol.
Old Aug 4, 2008 | 08:16 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: (Xscort)
I'll echo and say that I too have EK rear shocks on my EG, and I trimmed the rear LCA bushing to fit the more narrow EK lower shock forks.
...for those wondering about the fronts they fit exactly the same, but EK shocks lack brake hose mounting brackets, so you have to fab or zip tie them. EG shocks have brake hose brackets made onto them.
Jonsta
Apr 29, 2014 09:21 AM
batallic
Jul 17, 2008 05:51 PM
real_slow_EM1
Nov 8, 2004 01:54 PM
Dragger817
Jul 14, 2004 11:32 PM
RTW DC2R
10
Oct 12, 2003 06:15 PM
