95 Civic Hatch Brake Conversion???
Old Jul 28, 2008 | 10:23 AM
jdub01's Avatar
Default 95 Civic Hatch Brake Conversion???
Planning to upgrade Rear Drum To disc And go to 10.3 front rotors using type r calipers. I have the conversion kit from scarebird and using DX knuckles with type r calipers and brackets. Wondering if I use integra rear calipers can I use 99 Si e-brakes. And can I use 95 ex proportioning valve or should I go for 99 Si, also dont have ABS so Should I use Integra master cylinder? And Are the threads any different between these? And Would it be easier to use del sol rear calipers and would they work with this conversion kit? are they mounting holes different between del sol and integra calipers? Lots Of questions I know. Please Help..
Old Jul 28, 2008 | 10:49 AM
1992Si's Avatar
I wou;dn't bother with 99Si rears, unless someone can tell you everything is easy to do. THe lines on your Proportioning valve may be a nightmare.
The knuckles don't care that you don't have ABS Everything is pretty much the same.
98dxhatchbuild
Sep 23, 2017 02:29 PM
blue91EF
Suspension & Brakes
Jan 29, 2011 09:31 PM
91integra91
24
May 15, 2010 02:56 PM
machgo
Suspension & Brakes
Jan 21, 2010 03:36 PM
90AccordVTEC
Apr 26, 2006 10:30 PM
