Integra no start Part 2: Not starter or Main Relay
Old Jul 28, 2008 | 05:39 AM
reomi's Avatar
Default Integra no start Part 2: Not starter or Main Relay
A couple of weeks back my 1990 AT LS needed a new starter and a main relay rebuild nearly simultaneously. I'm in debt to the great suggestions and how to's from the forum.
New day. New problem.
I pulled into my spot in the parking garage at work, and I accidently turned off the car while it was still in drive, though I was a full stop in my parking space. Then, when I go to leave work yesterday and the car won't crank or spark, the starter isn't even engaging. The 3 clicks are there from the relay, but the ECU doesn't power up. I haven't checked for current in or out of the starter. The fuses seem fine.
Any ideas?
Old Jul 28, 2008 | 08:47 AM
icemangsr2's Avatar
Default Re: Integra no start Part 2: Not starter or Main Relay (reomi)
did you check the fuses under the hood? check the ECU fuse see if it's blown. shoudl be a 10 amp.
:::SIRll_EJ1:::
Nov 9, 2009 10:12 AM
Junkyard2000
Jul 4, 2005 10:55 PM
Sexy_Chantal
Oct 28, 2004 04:18 PM
PUSHER
Jun 21, 2004 11:21 AM
DsCivicEx
Feb 5, 2004 09:16 AM
