90 civic WONT START NEEED HELP!!!PLZ HELP
Old Jul 27, 2008 | 11:43 PM
phoenixyellowda9's Avatar
Default 90 civic WONT START NEEED HELP!!!PLZ HELP
OK o replaced my stock motor dual point in 90 civic hatch 4 speed and i forgot to connect the ground cable to the battery and thermostat housing ......the ground wire from the valve cover to front began to fry....so i connected grounds...started up no prob...3 mins later dead..........changed main relay,dizzy,gettin spark and fuel...checked firing order, changed ecu injectors checked all fuses ...new plugs new wires.....dont know wat else to do ......it turns over fine but wont start !!!!!!!!PLZ ANYONE imma have to take it to a shop and they gonna charge me ALOT!!
Old Jul 28, 2008 | 06:03 AM
beige89civic's Avatar
* B A N N E D *
Default Re: 90 civic WONT START NEEED HELP!!!PLZ HELP (phoenixyellowda9)
Check your starter cable and altenator power cables and see if you didn't pinch them. Gettig any codes?
Old Jul 28, 2008 | 09:20 AM
Default Re: 90 civic WONT START NEEED HELP!!!PLZ HELP (beige89civic)
no no codes
Old Jul 28, 2008 | 12:21 PM
* B A N N E D *
removed your battery ground cable and put a test light inline with the cable. IGNITION OFF. IF the test light stays lit you have a draw on the battery. We need to see what is drawing power to find out whats melting ground wires.
Old Jul 30, 2008 | 03:34 PM
so i changed to another dizzy same problem but all of a sudden it started idled good for liek 10 min hit the gas died started again hit the gas dies do im guessing fuel pump not grounding problem
Old Jul 31, 2008 | 05:18 PM
* B A N N E D *
Still no codes?
Old Aug 3, 2008 | 02:38 PM
nope it pissing me off haha i dotn know wat to do I MISS MY DA9
SpecialRequest
15
Jan 2, 2018 09:05 AM
patient49
Jun 29, 2015 05:46 AM
nexgen91
26
Nov 14, 2014 09:28 PM
B16afmaxt
Oct 19, 2009 04:30 PM
r b k a
20
Jul 26, 2009 02:40 PM
