Anyone ever installed the OEM optional remote entry/alarm?
Old Jul 27, 2008 | 10:17 PM
mstewar's Avatar
Default Anyone ever installed the OEM optional remote entry/alarm?
Bought the brain unit off someone awhile back but can't figure out where it plugs in at. The helms barely mentions it. Here is a crappy picture of where the harness would plug in:
The unit itself appears to be from Canada, but it seemed like it should still work. I poked around under the driver's side and couldn't find anything that looked like it would work.
Old Jul 28, 2008 | 03:09 AM
Bbasso's Avatar
Default Re: Anyone ever installed the OEM optional remote entry/alarm? (mstewar)
Interesting topic
If you give up on the install, I'll take it
Old Jul 28, 2008 | 03:47 AM
D's Avatar
D
The Brain mounts on the right hand side of the steering column bracket.
The only nice part of the OEM alarm is the hood switch. A much nicer mounted switch than the typical aftermarket push pin style.
Old Jul 28, 2008 | 04:28 AM
coolhandluke's Avatar
Default Re: Anyone ever installed the OEM optional remote entry/alarm? (D)
In my GS-R the unit is beneath the dash and mounted to the metal frame work behind it. It was towards the center of the car, facing the driver.
Old Jul 28, 2008 | 08:58 AM
walker111's Avatar
Default Re: Anyone ever installed the OEM optional remote entry/alarm? (coolhandluke)
Funny this thread popped up...
I have the factory alarm but its hooked up to the horn, I'd like to run the siren but dont know whats entailed.... Anyone know? Obviously I need a siren...what else?
sorry for the thread jack
Old Jul 28, 2008 | 09:03 AM
The Dude's Avatar
Banned
Default Re: Anyone ever installed the OEM optional remote entry/alarm? (walker111)
I needs to find my install instructions.
Jim I think you just need the OEM siren. I'm guessing when you plug it in to brain, it disables horn relay output.
Someone correct me if I'm wrong.
Old Jul 28, 2008 | 09:05 AM
walker111's Avatar
Default Re: Anyone ever installed the OEM optional remote entry/alarm? (The Dude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Dude &raquo;</TD></TR><TR><TD CLASS="quote">I needs to find my install instructions.
Someone correct me if I'm wrong. </TD></TR></TABLE>
Well I know that there is a switch on the box, but I was wondering if there was another harness for the siren...
Old Jul 28, 2008 | 09:08 AM
walker111's Avatar
Default Re: Anyone ever installed the OEM optional remote entry/alarm? (KOALA YUMMIES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">You have to buy the harness for the alarm unit, for your year of car. Then if you want the siren and hood pop sensor you need each of those plus the harnesses for them, Len knows all about this. </TD></TR></TABLE>
Sweet, anyone have the part number for the harness? sgt gave me a harness but we are unsure if its the correct part.
Old Jul 28, 2008 | 09:12 AM
The Dude's Avatar
Banned
Yup, harness goes in behind drivers kick panel in the footwell. I went home with two boxes, Alarm and harness. I'll see if i can find the damn inst. sheet when I get home. I have the boxes with P/Ns for '97-'98 ITR. Jim, I never popped for siren, so don't have the P/N for that, solly.
Old Jul 28, 2008 | 09:58 AM
mstewar's Avatar
good info.. sounds like i am missing the harness to make this work. No wonder I couldn't find where to plug it in.. I really just wanted the remote entry most of all and the horn alarm sounded like a bonus..
and now that you guys mentioned it, I found the list for all years on Carland's website:
http://www.acuraautomotivepart...urity
Koala yummies, do you want to sell that main harness? looks like the part number is the same as listed for the 98..
Old Jul 28, 2008 | 10:18 AM
walker111's Avatar
Scott, I sent a a pm.... I just went out and checked mine, need some questions answered. Would rather not put them out over the intraweb.
Old Jul 28, 2008 | 10:57 AM
KOALA YUMMIES's Avatar
Werd, I replied Jim.
Old Jul 28, 2008 | 11:02 AM
get RIGHT's Avatar
Does this alarm also require the use of the stock radio like the Civic's do?
Old Jul 28, 2008 | 11:09 AM
get RIGHT's Avatar
Is that for the anti theft on the stereo or what?</TD></TR></TABLE>
Correct.
Old Jul 28, 2008 | 12:23 PM
mstewar's Avatar
the only anti-theft on the radio is the radio code itself.. shouldn't be related to the alarm system at all.. my first R already had it installed when I got it, and I replaced the head unit without issue..
Old Jul 28, 2008 | 12:31 PM
get RIGHT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstewar &raquo;</TD></TR><TR><TD CLASS="quote">the only anti-theft on the radio is the radio code itself.. shouldn't be related to the alarm system at all.. my first R already had it installed when I got it, and I replaced the head unit without issue..</TD></TR></TABLE>
If you don't see any plug ins going into the radio then it probably doesn't.
Old Jul 28, 2008 | 12:36 PM
walker111's Avatar
OP, you putting this on a 98? After talking to Len, his master catalog says that the "alarm" mechanism is not available for the 98's. Only thing you would be able to use is the lock unlock.
If you get the harness from Scott, you'll be at the point I am. Looks like my hopes for hooking up a siren are gone.
Old Jul 28, 2008 | 02:08 PM
mstewar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">OP, you putting this on a 98? After talking to Len, his master catalog says that the "alarm" mechanism is not available for the 98's. Only thing you would be able to use is the lock unlock.
If you get the harness from Scott, you'll be at the point I am. Looks like my hopes for hooking up a siren are gone.</TD></TR></TABLE>
Yep.. This is going on a 98.. I only wanted the remote locks functionality and if the horn alarm ended up working too, that's great..
Old Jul 28, 2008 | 02:44 PM
I'm not sure what the prices are for these parts, but you may be better suited upgraded to a DEI unit- especially if this is the one you plan on keeping. I know you are looking for keyless entry, but my thoughts are coming from a security standpoint. I did my own alarm install in the gs-r last November with the help of Desmon(wrx-eater-sti-killer.) I learned quite a bit through him and the install process.
Old Jul 28, 2008 | 03:45 PM
walker111's Avatar
Yep.. This is going on a 98.. I only wanted the remote locks functionality and if the horn alarm ended up working too, that's great..</TD></TR></TABLE>
You should be good with that. Thats what my car does...Only thing I dont understand is that my horn will go ape **** if i reach through an open window unlock the door and open it if was locked from the keypad.....
Beats me....anyone have a used OEM alarm with siren for sale?
Old Jul 28, 2008 | 05:17 PM
The Dude's Avatar
Banned
Beats me....anyone have a used OEM alarm with siren for sale?</TD></TR></TABLE>
That's the alarm Jim, works off the door domelight switches. I think the brain also has a glass break sensor. (There will be a sensitivity adj. on the box.) There's also a switch or two for other functions.
Old Jul 29, 2008 | 03:48 AM
walker111's Avatar
That's the alarm Jim, works off the door domelight switches. I think the brain also has a glass break sensor. (There will be a sensitivity adj. on the box.) There's also a switch or two for other functions. </TD></TR></TABLE>
Yea I saw the switch for the siren/horn and the sensitivity switch....but apparently there is no accessory harness (siren/hood switch) for the 98. I'm gonna figure it out....I'll let everyone know what I find.
Old Jul 29, 2008 | 03:58 AM
The Dude's Avatar
Banned
Yea I saw the switch for the siren/horn and the sensitivity switch....but apparently there is no accessory harness (siren/hood switch) for the 98.</TD></TR></TABLE>
I think you need these.
08E49-ST7-201F - 98 Siren kit
08E49-ST7-200G - 98 Hood Switch Kit
08E51-ST7-203G - 98 Security System (what OP has)
08E55-ST7-200G - 98 Attachment Brkt. and Harness for above ( what OP needs to hook up)
Modified by The Dude at 7:05 AM 7/29/2008
Modified by The Dude at 7:08 AM 7/29/2008
Old Jul 29, 2008 | 05:06 AM
len's Avatar
len
http://www.acuraautomotivepart...urity</TD></TR></TABLE>
Be careful. Like I told Jim, I see that the website shows those part numbers for the 1998 models. However in my master catalog, nothing shows up. Probably why Jim is having a difficult time finding where to plug his harness. Cheers!
Old Jul 29, 2008 | 07:14 AM
walker111's Avatar
Default Re: Anyone ever installed the OEM optional remote entry/alarm? (len)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by len &raquo;</TD></TR><TR><TD CLASS="quote">
Be careful. Like I told Jim, I see that the website shows those part numbers for the 1998 models. However in my master catalog, nothing shows up. Probably why Jim is having a difficult time finding where to plug his harness. Cheers! </TD></TR></TABLE>
I just need to find someone with the factory alarm...
Thanks for your help, Len.
