please help me identify this CEL code
i'm so proud i can learn to do this...whoo-hoo! only problem is i don't know what the problem is. i did the old method way-- paper clip stick in the plug. i've counted 5 slow flashes, and 3 fast flashes.
now you wizards tell me what that is??...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OMGWTFBBQ! »</TD></TR><TR><TD CLASS="quote">Code 53, which is a generic code,
53 PCM failure
53 Internal controller failure
Replace the PCM
Do I know what a PCM is, no. But google does.
how did you come up with that? i have no idea what PCM or IC is...but i will try my best to figure it out.
thanks!
53 PCM failure
Replace the PCM
thanks!
I just googled CEL code 53, and got a list of errors.
I googled PCM, but no one actually said what it was, just used the acronym. I also only searched one page of results. I would imagine CM stood for control Module, so whatever P is will give you your answer.
It should only come on once. If you have misfires, then it will blink 4 times when it detects a misfire, and youll have individual cylinder misfires codes, along with a random misfire code if more than one cylinder is misfiring.
You should redo the jumper wire method. I couldn't find CEL code 53 on the list:
https://honda-tech.com/zerothread/1901557
Maybe the code actually was 54 or 63?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RonJ@HT »</TD></TR><TR><TD CLASS="quote">You should redo the jumper wire method. I couldn't find CEL code 53 on the list:
Maybe the code actually was 54 or 63?</TD></TR></TABLE>
maybe i should go redo it again?
you know what...it could be 4-3 after all. and that must be-"fuel supply system." can anyone explain to me what that is?
PCM = Powertrain Control Module. As far as I can tell, this refers to the ECU.
http://www.aa1car.com/library/pcm.htm
is code 43 the reason why my car bogs and chokes? and cel only came on once and so far it hasn't been showing again. could it be popping back up again?
i will try and change the fuel filter first, and then 02.
You want to be absolutely sure that the code was 43 before you begin replacing parts. Clear the ECU by removing the 7.5A BACKUP fuse for 30 seconds and then reinsert it. Drive the car and, if you again notice the CEL ON, then retrieve the code(s) and go from there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RonJ@HT »</TD></TR><TR><TD CLASS="quote">You want to be absolutely sure that the code was 43 before you begin replacing parts. Clear the ECU by removing the 7.5A BACKUP fuse for 30 seconds and then reinsert it. Drive the car and, if you again notice the CEL ON, then retrieve the code(s) and go from there.</TD></TR></TABLE>
hey good morning, Ron. i tried to IM u, but you blocked it.
ECU is the black box under the hood? remove how many 7.5? lets get it started this morning.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2_Fella »</TD></TR><TR><TD CLASS="quote">ECU is the black box under the hood?</TD></TR></TABLE>
No, that would be the underhood fuse panel, your running a '92 - '95 civic right? ECU is behind the passengers side kick panel, its held in with 3 bolts and one nut
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2_Fella »</TD></TR><TR><TD CLASS="quote">remove how many 7.5? lets get it started this morning.</TD></TR></TABLE>
remove the 7.5 amp fuse labled backup, leave it out for 30 seconds and then put it back in, you will loose your radio presets as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EG8 »</TD></TR><TR><TD CLASS="quote">
remove the 7.5 amp fuse labled backup, leave it out for 30 seconds and then put it back in, you will loose your radio presets as well.</TD></TR></TABLE>
hey what sup, 94! i remember you, you're a big helper!
damn, i should've known...been driving honda's for over 10 years and i feel so stupid not knowing where the ECU is. so it's that gold metal box? right under the grey plug?
can't wait to go and try and open it. i need to disect my car a little more. i'm just so scared i might break things.
so if i remove the fuse, do i drive it around for a little bit? after that, do i come back and do the clip on the socket again and recount it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2_Fella »</TD></TR><TR><TD CLASS="quote">so it's that gold metal box? right under the grey plug?</TD></TR></TABLE>
Yep, thats the ECU
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2_Fella »</TD></TR><TR><TD CLASS="quote">so if i remove the fuse, do i drive it around for a little bit? after that, do i come back and do the clip on the socket again and recount it?</TD></TR></TABLE>
You just need to pop the fuse out for 30 seconds or so to clear any codes, put fuse back in and drive around till the light comes on, then check your codes again. I was hoping you were having better luck with your car. Has it ever gotten any better since the headgasket fiasco? Anyway good luck
Yep, thats the ECU
Yep, thats the ECU
i ended up spending more than what i should have. "you get what you pay for." i hired a mickey mouse mechanic.
i paid to have someone adjust my valves. by-pass hose went bad after the headgasket when it should've went bad while getting the head done. car shakes at idle. car bogs and chokes even more.
*CEL* light hasn't been lighting up since saturday night. why's that?
Yep, thats the ECU
</TD></TR></TABLE>i ended up spending more than what i should have. "you get what you pay for." i hired a mickey mouse mechanic.
