Some car trouble
Old Jul 27, 2008 | 07:38 PM
citystars41's Avatar
Default Some car trouble
so to start this off, it all began when i replaced my transmission. had a difficult time doing that but after all said and done, the car wouldn't start. Makes no sense i know. after replacing everything except the problem, i finally switched out my coil and put my old external coil in the car. that got the car running, but now there is something else wrong. when starting the car the lights are dim in my car and i have to rev it up to 4000 rpm to get it to the normal lighting. just the other day too i was driving down the highway and the car just gave out but it was still running but i couldnt give it any gas. i down shifted and it went back to normal. does anyone know what could cause this problem?
Old Jul 27, 2008 | 07:51 PM
94EG8's Avatar
Seagull Management
Default Re: Some car trouble (citystars41)
My guess is you forgot to put the transmission ground wire back on, or you put it back on but its making poor contact.
Old Jul 28, 2008 | 06:40 AM
Default Re: Some car trouble (94EG8)
that was my first thought too so i went through and made sure they all had a nice strong connection
Old Jul 28, 2008 | 06:44 AM
DTA-Zombie's Avatar
check your contacts again - take a wire brush over the areas with the ground strap removed and rebolt it...ur getting low power so if not that battery or alternator.
moleodonuts
16
Jan 17, 2022 09:59 PM
SaveDaNoob
Apr 24, 2011 09:12 PM
yeshie
Nov 26, 2007 05:41 AM
tancivic
Nov 1, 2004 12:06 PM
Urban Business
24
Oct 3, 2002 01:11 PM
