need help!!!
Old Jul 27, 2008 | 06:04 PM
turbodelsolb16a2's Avatar
Default need help!!!
i have a 97 civic ex with b16a2 swap.....the radio dash cluster harness got burnt and it fried my ecu so i got a new harness and a new ecu....but now when ever i put in the key and turn the ignition it tries to turn on by itself....and it sounds weak like if it didn't have preasureor something....i can't explain it....i don't know if it was my fuse box thats burn out or something else....but if any one has any ideas please let me know......thanks
Old Jul 27, 2008 | 08:11 PM
Default Re: need help!!! (turbodelsolb16a2)
any one?
Old Jul 27, 2008 | 08:14 PM
OMGWTFBBQ!'s Avatar
You're saying when you put the key to the on position, the engine starts to crank?
You my friend have a bad wiring problem with your ignition harness.
Old Jul 27, 2008 | 08:21 PM
Default Re: (OMGWTFBBQ!)
idk cause it won't stop until i disconnetcted the starter....but it only started to do that when i checked the fuse box i removed it and then i put it back and it started to do that.....
Old Jul 29, 2008 | 08:58 PM
Default Re: (turbodelsolb16a2)
any one else have any ideas?
lolv8s
May 17, 2013 05:20 PM
turbodelsolb16a2
Aug 22, 2008 03:25 PM
T_bones
Jun 19, 2007 05:08 PM
Turbo Dan
Oct 13, 2005 09:10 PM
dabiddan
Nov 23, 2004 11:08 PM
