Oil Burning Prelude - Need Help
Old Jul 27, 2008 | 05:33 PM
bhensoH22's Avatar
Default Oil Burning Prelude - Need Help
I was wondering, on average, how many miles it takes anyone's prelude 97-01 to burn a quart of oil. I have a '98 Type SH with 155,771 miles. She normally takes about 600 miles or so to burn a quart. But I just checked her and it took like 400 miles....Yikes!
I am wondering if she is about to take a **** on me or if those numbers are average. I rarely hit vtec and never drive her hard. I know its sacriligous but I get pretty good mpg while having a light foot and keeping under 4K rpm.
Please email me any thoughts or comparisons. I would really appreciate it. My email is bhenso7@aol.com
THANKS!!!!!!!!!
Old Jul 27, 2008 | 06:01 PM
Kronn 98SH's Avatar
Default Re: Oil Burning Prelude - Need Help (bhensoH22)
if i understand you correctly, you're saying your lude burns through a quart of oil only 600miles after an oil change. If so, WOW!
Old Jul 27, 2008 | 07:44 PM
PearLude99's Avatar
ludes do burn alot.. specially on vtak!
Old Jul 27, 2008 | 08:09 PM
h23siaws's Avatar
mine burns a quart about 1k, so i switched to 10w40, helps a lil bit, burns 1 quart about 1500.
Old Jul 27, 2008 | 08:16 PM
vinuneuro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bhensoH22 &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering, on average, how many miles it takes anyone's prelude 97-01 to burn a quart of oil. I have a '98 Type SH with 155,771 miles. She normally takes about 600 miles or so to burn a quart. But I just checked her and it took like 400 miles....Yikes!
THANKS!!!!!!!!!</TD></TR></TABLE>
You just about described my 98 SH. It's the oil control rings that are the problem. Are sure there aren't any oil leaks? What you need are new rings, but until you fix the problem, nothing bad will happen as long you keep the oil topped off.
Old Jul 27, 2008 | 08:32 PM
bb6ludey's Avatar
i have the same problem, check ur oil control rings, liek the guy above me said :]
Old Jul 28, 2008 | 05:48 PM
championracer_DB8's Avatar
yea sounds like the rings or you may just need to use a thicker oil....
Old Jul 29, 2008 | 07:02 AM
imloggedin's Avatar
Check vigorously for leaks before you come to that conclusion.
Old Jul 30, 2008 | 03:10 PM
mattsnooz's Avatar
Default Re: (imloggedin)
("HYOK HYOK" (laughing of a moron/idiot) why don't you'all use some o that leak stop chemical things you put in your motor?)
I wouldn't say go to a thicker oil. Stick with 5w30 just use a quality synthetic brand for a couple months and see if the burning lessons.
A thicker oil would likely cause More friction which would generate more heat, which would likely burn oil more easily?!, thats what I would think anyway.
I would say use the same viscosity your motor is suppose to run with, and go with an oil that can handle the higher temperaters that our hot running high reving honda motors opperate at. (this is all my thoughts, if its wrong please inform me)
Old Jul 30, 2008 | 03:18 PM
vinuneuro's Avatar
Default Re: (mattsnooz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattsnooz &raquo;</TD></TR><TR><TD CLASS="quote">("HYOK HYOK" (laughing of a moron/idiot) why don't you'all use some o that leak stop chemical things you put in your motor?)
I would say use the same viscosity your motor is suppose to run with, and go with an oil that can handle the higher temperaters that our hot running high reving honda motors opperate at. (this is all my thoughts, if its wrong please inform me)</TD></TR></TABLE>
There's a lot of wrong/bad information in this post. If you're not sure, don't post anything.
Old Jul 30, 2008 | 06:26 PM
Rob97'SH's Avatar
Default Re: (vinuneuro)
Although, ludes burn alot of oil more so while in vtec. If your using a quart per 600 miles and have no leaks ( seepage is normal, dripping isnt) I have a hard time thinking its the rings. More likely its your valve seals or valve guides. These (seals) are more likely to fail just to age rather then mileage. I wouldn't go to thicker oil but stick to stock oil rec unless your running a turbo. Try not going into vtec for a tank full and see if it reduces. Also are you seeing blue smoke when you step on the gas? Try doing a leak down test on the cylinders and a compression test.
Old Apr 16, 2009 | 05:00 PM
prelude_93vtec's Avatar
Hey I'm going through a quart like every week. I use Royal Purple 5w30 and it gets real expensive lol. I just changed my oil cooler o ring and some seals are leaking but I don't think thats it. I get a bad smell of oil if I floor it and people say I leave a cloud of blue smoke but mainly when I floor it. Compression is good, what else can it be?
Old Apr 16, 2009 | 05:04 PM
ADE1's Avatar
I too used to give my lude a quart of oil at least every week in a half.
Old Apr 16, 2009 | 07:22 PM
autoluder's Avatar
Where are the oil control rings?
I have a H22a and it burns a quart a month, and i had all the seals replaced when i did my swap. I do engage vtec alot. And when i punch it it always leaves a white cloud behind. And no oil leaks on the ground.
Old Apr 16, 2009 | 09:31 PM
spoonfedcrx's Avatar
On the piston.
Haha about people complaining burning oil. My 93 4ws goes through 2.5 qts a week. **** looks like a cropduster. I just top off the oil everytime I get. 275,000 miles on og engine, going to rock this bitch to the wheels fall off.
Old Apr 17, 2009 | 12:44 AM
meanshyguy's Avatar
^^haha, you should take care of your car!!
Old Apr 17, 2009 | 05:00 AM
NormanBates's Avatar
zMax it!
Old Apr 17, 2009 | 12:50 PM
Originally Posted by NormanBates
zMax it!
uhhhhh no.
Old Apr 18, 2009 | 07:31 AM
autoluder's Avatar
Okay I think i have part of the answer, most of the oil being burned is the oil that gets recirculated back into the intake. I think the oil catch can mod, can at least stop the white clouds every time you punch the gas. But the oil consumption will remain the same. ha..
Old Apr 18, 2009 | 09:59 AM
uhhh no
Old Apr 18, 2009 | 12:38 PM
DaInFaMMuS1's Avatar
I thought it was normal for H motors to burn about a quart every 800-1500 miles? Being that i regularly engage vtec, i dont think thats too bad for my motor.
Old Apr 18, 2009 | 09:15 PM
Kool_cat26's Avatar
New User
I have a 92 with H22a and I have alot to learn. Thank you guys for all the helpful info.
Old Apr 18, 2009 | 09:27 PM
carvers's Avatar
since were on the subject of h22's and oil. im dropping one in a hatch this week any i need to do to it pertaining to oil before i put it in while its out.
Old Apr 18, 2009 | 09:31 PM
autoluder's Avatar
Originally Posted by spoonfedcrx
uhhh no
uuhh yes. that tube that goes off the head to the intake tube, and the other one that has the pcv valve to the intake manifold, what do you think those two lines do. Decoration? When the pcv valve closes. oil goes through the other orfice back into the intake tube where it gets burned off by the engine.
Old Apr 19, 2009 | 06:47 AM
Uh not one place in my post did I say anything discussing the operation of the pcv valve. And what does that have to do with "white clouds" when you "punch" the gas?
So I'll say again.....uh no.
