Is there a lightweight torque converter/ flywheel for an automatic h22a prelude?
Never heard of one, but a lightweight torque converter would most likely be pretty expensive. An auto doesn't have a flywheel, so I don't know what you mean there, but the flexplate on an auto is already pretty light.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 »</TD></TR><TR><TD CLASS="quote">An auto doesn't have a flywheel, so I don't know what you mean there, but the flexplate on an auto is already pretty light.</TD></TR></TABLE>
Isn't the flywheel/flexplate the same thing?
And if your looking just to lose some weight, there are better solutions then getting a lightweight flexplate/flywheel...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude_93vtec »</TD></TR><TR><TD CLASS="quote">
And if your looking just to lose some weight, there are better solutions then getting a lightweight flexplate/flywheel...</TD></TR></TABLE>
No....
Flywheel:
Flexplate:
No friction surface on the flexplate. Also a lightweight flywheel is a great modification, but if you just want to drop the overall weight of the car it won't change it a whole lot.
No....
Flywheel:
Flexplate:
I remember the flexplate on mine when I was converting mine to manual trans, I was like "what is this ? its so light i tossed it like a boomerang" lol!
performance mods for autos would be more along the lines of a shift kit or performance torque converter, all of which is not really specialized for imports. Just get a manual, and be done with it.
it wouldnt be a lighter torque convertor it would be a stall, i dont know if they make any for an h but why dont u just go with a 5 speed? honda auto trannys dont hold up to power and are not for performance in any means
Thanks for your very wise correction of how a flywheel an a flexplate are different, but you knew what I meant didnt you. This is for a circle track stock car, so I am not trying to dump a lot of money into a conversion. I wont even be shifting. It goes in second or third gear and stays there. I just wanted to know if there was any little things I could do before i put it all together.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weev »</TD></TR><TR><TD CLASS="quote">Thanks for your very wise correction of how a flywheel an a flexplate are different, but you knew what I meant didnt you. </TD></TR></TABLE>
No, I didn't know what you meant...just trying to be technical I suppose.
put a 5speed in 2 gear and an auto in 2 gear and see the 5 speed leave the auto like its standing still its a waste.
