FS/FT: Darton dry sleeved block
I got my Benson block which is good to 60psi, so im selling my Darton block which is only good to 30psi. The block does need to be bored to 81.5 mm as the last person who had it ran the piston to wall clearances to tight at 81mm and caused some scarring. I picked this block up from gsrhb7 so i know its legit.
These are dry sleeves as opposed to wet sleeves in the benson and the difference can be found here
http://www.darton-international.com/tech_ctr.htm
Here is a pic of a stock honda b18
And here is the pic of the dry darton sleeves
Heres the block itself
You can see the sleeve is almost twice as thick. Its what Darton calls the 300 series sleeves which can be seen here
http://www.dartonsleeves.com/sb_assy.htm
And here is the wet sleeve
I paid $400 for it so thats what i want out of it. Or make offers on trades.
Make offers on trades....i need just about anything turbo related. EG duckbill, carbon hood, just about anything EG related. Im pretty open to trades.
