What's the differences between peak/hold and saturated injectors and can I use either with mod?
Old Jul 21, 2002 | 02:14 PM
glagola1's Avatar
Default What's the differences between peak/hold and saturated injectors and can I use either with mod?
I guess the topic says it all. Thanks
Old Jul 21, 2002 | 02:24 PM
b18bturbo's Avatar
Default Re: What's the differences between peak/hold and saturated injectors and can I use either with mod?
what is based on low resitance across the terminals and the other is based on high resistance.
If your car has high resitance which most hondas have then you would need a resistor pack to run the low resitance injectors.
Its always good to match the ecu to the injector driver based on your ECU and wiring.
Old Jul 21, 2002 | 02:27 PM
glagola1's Avatar
So I've got a 94 civic Si which is peak and hold. Do you suggest staying with peak and hold or can I get saturated and run a resistor pack? I'm looking for some 310 injectors and I wanted to grab them from a junkyard. hmmmm
thanks btw
Old Jul 21, 2002 | 02:29 PM
b18bturbo's Avatar
when you grabbing hte 310cc if its peak hold nothing will have to change if you plan on running say 550cc and higher you will probably only find low imp type injectors.
bigblue7t6
Engine Management and Tuning
Oct 5, 2012 08:31 PM
prelude2121
Oct 29, 2010 02:40 PM
swt_666
May 16, 2007 09:33 PM
H.A.R.T B18C1EG6
Jan 4, 2005 11:10 AM
dkdjlf
Sep 19, 2003 02:31 AM
