stretch bolts
im doing a mini-me with the engine out of the car and i figured i might aswell throw in a sport clutch while im at it. are the headbolts and flywheel bolts stretch bolts? ive seen people reuse the headbolts but im not sure and want to get a solid answer, thanks!
All bolts stretch.
You can reuse them if the engine has never overheated. I would torque them an extra 5 lb-ft to be safe. However, ARP head studs are good insurance. It's up to you.
For what its worth i asked my local honda dealership sometime ago if they use new headbolts when they replace a blown headgasket, they don't. I was surprised. Especially since every manual i ever read said always replace with new bolts.
I don't know if I'd trust OEM bolts after a blown head gasket. If the aluminum expanded enough to stress the bolts beyond their yield strength, they're worthless. However, I've never done the math, so I don't know how hot the engine can get before the bolts are plastically deformed.
I don't think the Helm's manual says to replace head bolts. Maybe I missed that blurb.
yeah thats what some local honda shops told me too, they dont replace them, the engine has never been overheated, so they should be good to use with an extra 5lbs of torque? should i use loctite?
igo4bmx
Nov 25, 2004 09:43 PM
