Is an Idle Control Valve needed?
Old Jul 27, 2008 | 08:04 AM
AE92boost's Avatar
Default Is an Idle Control Valve needed?
My question is, is an Idle Control Valve necessary when going with a full standalone?
Im going to be making my own intake manifold, using an aftermarket 75mm Mustang throttle body which has no provisions for an ICV, along with a full Microtech standalone. I fully understand how an ICV works... its basically a vacuum leak controlled by a stepper motor, solenoid, or coil that allows for better cold start driveability.
Since the standalone I will be using has full enrichment control based on coolant temperature, couldn't I just tune that? or is a vacuum leak still necessary for something other than emissions?
Old Jul 28, 2008 | 09:56 AM
EnjoyTheRideDC2's Avatar
Default Re: Is an Idle Control Valve needed? (AE92boost)
You dont need to run an IACV. If you're making a custom manifold and there is no provisionary spot for it, then you have to route the coolant lines as if there never was a valve present.
Search "Throtthe Body Bypass" or "Coolant Bypass" or IACV bypass and you'll find info on how to eliminate it all together.
wondersparrow
May 10, 2008 05:41 PM
h22vt
Apr 20, 2006 09:34 AM
shabasoft
Dec 22, 2004 04:05 PM
Gennady
Jan 21, 2002 04:39 AM
